Screen To Camera icon Screen To Camera — Capture any screen area and stream video to a configured camera device; requires a Custom device and 100% display scaling. Try it →
Super easy dude , 2 main ways. First is the way he does in the video which is he cut the wires going to the potentiometer in the servos and ran longer wires to larger pots on the duplicate arm. Each joint has one potentiometer to represent a servo that would actuate it. As the arm moves the servo control board moves the other arm. The other option is using pot to give position feedback and then use ARC to match the position with the servo position. It's like how the robot supersoldier suites work too. Read your slight movement and then move servo to match.
