TCP Client icon TCP Client — Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo Try it →
You can only edit the project in Windows, but there are mobile apps that can open and operate existing projects, including the JD sample project from iOS and Android.
Minimum version of Android is 4.something. Not sure about the minimum iOS version, but the app store should not present the app to you if you are on an incompatible version.
Here is a little more info:
https://synthiam.com/Tutorials/Lesson/60
This tutorial however doesn't explain how to connect an iOS device to the EZ-B WiFi.
There are two choices, either, after downloading the app, start the EZ-B, and in the iOS WiFi settings, connect to the EZ-B's access point. Its IP address will be 192.168.1.1 when you go back to the app.
Or, connect the iOS or another computer to the EZ-B's access point, and connect to 192.168.1.1 and provide the EZ-B with your WiFi router's credentials. It will reboot and connect to your network. Then in the iOS app, under the connection dialog, you can scan for the IP address on your network.
See https://synthiam.com/Tutorials/Lesson/15?courseId=5 for more information about the connection modes.
Here's the mobile link in the software page: https://synthiam.com/Products/ARC
You can find menu options at the top of this website which will bring you to different sections, such as Software and Products.
