Controlling Servo Speed And Fluidity With Joystick Control
I recently posted a question about getting my PS3 to work with ARC. I now have a driver that allows it to be recognized and connect. The issue I am having is with the speed of the servos and the robot jitters. It just isn't a smooth movement.
I am using a dynamixal robot arm (AX12) and an OpenCM controller. Is there a way to control the speed or sensitivity of the joystick movement? I have read most of the joystick threads and other materials, but I don't find any reference to how you can have "finer" control over how the joystick is moving the servos.
If I purchased a different joystick would it behave differently? If so, I would appreciate a recommendation on which joystick works best with ARC.
Appreciate any help. Vicki
Opencm 9.04 by Robotis
OpenCM 9.04 with Synthiam ARCx drives Dynamixel servos in a web browser for animations, scripts, AI and hardware I/O
USB
Servos 200
ADC ✕
Digital ✕
XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts.
Probably the servo position range on each axis. The joystick only has a finite resolution that’s being mapped to a large degree range.
lower the range per axis
