Lynxmotion Smart Servos icon Lynxmotion Smart Servos — Compact Lynxmotion Smart Servos with position feedback, safety features and UART TX/RX for Arduino/EZ-B v4; scriptable temp, load, load-dir and ping. Try it →
Have you tried using this formula? ...
$far = (GetCpuTmp() * 9/5) + 32
No, I was assigning the GetCPUTemp to a variable and then doing the math with the variable. Will try and get back to you.
Crashing ARC? That's not easy to do. I'd like to see your code. Anyway, here is a method. I tried it and it does not crash.:)
$CTemp is temperature in Celsius $FTemp is temperature in Farenheit
$CTemp =GetCpuTemp()
$FTemp =($CTemp * 1.8) +32
Print("Celsius ="+$CTemp) #So you can see the results in the debug window
Print("Farenheit ="+$FTemp)
little more complex than Richard's answer, but tested...
#initialize variables
$temp = ""
$ftemp = ""
#get cpu temp
$temp = getcputemp()
#convert to f
$ftemp = $temp * 1.8 + 32
#display result  You could also speak it, etc...
print($ftemp)
Perfect. Thank you.
OK guys, all together now ...
Richard R._____ WBS____________You're Welcome! Alan_______/
Yes, the whole group is awesome and very quick to respond.
