Command Duplicator icon Command Duplicator — Duplicate and synchronize commands from one master EZ-B to multiple slave EZ-Bs for simultaneous, mirrored robot actions. Try it →
Converting A String To Integer In Ez Scripting
I am using the plug in for the XV-11 Lidar. The output of the plug in an array in which each value is a string that represents the distance at the angle and the signal strength. To use this for control of the robot, I need numbers at these angles. The format is shown in the attached example. How do I parse and convert this in EZ Scripting into an integer?
In C there is the string.split command
https://msdn.microsoft.com/en-us/library/b873y76a(v=vs.110).aspx
and then the string to integer convert.
Is there a way to do this in the EZ scripting?
#57
The angle is the item of the array.
$LIDARDistance[0] would be for the value for angle 0 $LIDARDistance[1] would be for the value for angle at 1 degree . . .
The distances you are seeing would be something at about 19 1/2 inches from the LIDAR.
The distance value / 25.4 should give you the inches at that angel.
#58
yea, it sounds like it is an issue with the com port. I bet if you install the Teensy Serial Driver you would be okay. You might need to uninstall the existing Teensy driver before installing it again.
#59
It could also be the cable I suppose. I use a 1.5 foot cable. It is pretty heavy grade for a usb cable. I have run it before with a much longer (10 foot) cable without any problem though. This was from a powered usb hub.
#60
Uninstalled com2 drive, download your for the Lidar sub serial driver, opened ARC changed to c8 saved and it locked up.
Rebooted pic still locking up, ugh! Am I the only one running win7?
Any suggestions thanks
#62
Ok no luck. Getting real frustrated now calling it a night I got a headache and I'm tired look into it tomorrow thanks David
#63
One more quick thing David I'm not mad at you I'm just frustrated because it's been running for a long time with the version 2-18 date I believe it was. confused
#64
Not a problem. I am going to send you a version that will tell us exactly what it is doing when it locks up. I will make it tomorrow and send it your way. I'll call you to walk you through getting it in place to run.
