PWM Slider icon PWM Slider — Slider to set EZ-B digital PWM for motor speed or LED brightness; shows duty-cycle, stop button, and board/port selection. Try it →
Microsoft Windows has shortcuts for common commands. The commands are actually universal between Mac and PC. They are as follows...
CTRL-C is COPY CTRL-X is CUT CTCL-V is paste
Open the script you want to copy. Highlight all and then use CTRL-C... Then create or open a second script and then use CTRL-V to paste the contents of the first script...
Thanks, that worked.
You can also use the merge function to copy existing script examples into your current project.
