Programming With Pictures icon Programming With Pictures — Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots. Try it →
A little more info is needed really as we have no idea what increases the count. Also, technically a string is alphanumeric not numeric so couldn't be a counter.
But make the script from the following elements...
First define and set the variable
$counter = 0
Have your script do whatever needs doing and when the counter needs increasing by one use
$counter++
So, for instance, if you wanted something to loop 100 times the code would be
$counter = 0
RepeatWhile ($counter < 100)
  Print($counter)
  $counter++
  Sleep(100)
EndRepeatWhile
But if you wanted the counter to count how many times the camera started tracking it would be
$counter = 0
:loop
IF($CameraIsTracking = 1)
  $counter++
EndIf
WaitForChange($CameraIsTracking)
Goto(loop)
@Rich Thank You for the quick response. What you have provided gave me the answer I was looking for.
