Serial Terminal icon Serial Terminal — PC and EZB serial terminals for ARC: connect, monitor and send text/ASCII to serial devices. Supports COM, flow control, baud, DTR/RTS, hex Try it →
Resolved Resolved by Jeremie!
Covered in schmutz...
Covered In Schmutz...
So my first developer kit has finally arrived, and I'm excited to bust out its contents and start experimenting with them. To my surprise, I find that the EZ-B is covered in some kind of liquid, almost as if someone in the middle of packing it had opened a bottle of coke next to it.  Everything else seems to be perfectly fine and pristine, but I'm afraid of this EZ-B not working properly, especially if I try to clean it myself.  Has anyone else had this issue?
Wait, im confused, lol. @DJ ? are you not EZ-robot and Synthiam? your the one who started EZ-robot correct? just wanted to get the whos whos straight.:)
Isopropyl did just the trick, and pretty easily at that. Thank you.:)
On to the experimenting!!
Ah, that looks normal:D Sexy EZ-B v4.x/2!! I can tell it's a /2 because you can slightly see the silver metal cover over the wifi components above the camera port
