Movement Script icon Movement Script — Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ). Try it →
Hello to all, Well, I am out of data ports. Yes, I have used all 20 and need more. Is there a way to run two EZ-B's in conjunction? I don't think so. DJ, would you build me a duo? Is it feasable? I read on the forum where someone added a whole bunch of additional inputs but that is like running two servos off of one port and that will not work. Any solutions out there?
Hahahha. Wow. Just unreal dude:)
Are u using ARC or ur own custom app?
DJ, I am using ARC. Can you rig up something so I can run two EZ-B's at the same time in the same robot?
I have put thought in the past on how to make the ARC control more than one ez-b. The problem lies in the scripting engine. I'd have to think a bit about that.
I don't wnat to make the scripts overly complicated for the majority of users who only have one ez-b.
Let me ponder:)
