Custom Movement Panel icon Custom Movement Panel — Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors Try it →
It's awesome:D
I have been fiddling with the idea of making user defined functions in ez-script. It would be a control where you can define the function and parameters.
My first thought was to make the function be ez-script. But lately i've been leaning toward the idea of having the function be c# to give additional functionality. That means you could create the c# code for the internal function and be
  1. extra fast
  2. have control over the ARC architecture just like a plugin
@DJ... Great idea.... User defined functions would be awesome....
@DJ,
I'm glad you raised that topic.
Plugin: the concept is neat, but as you know does not work on Mobile and Windows Universal Apps
user functions: I would do it first in EZ-Script, as you know C# CodeDom/Generation is not allowed on IOS Apps.
that way you can use user functions everywhere.
I was thinking of the user function being similar to a plugin's version management and shareable in an online library.
if the function is a mere EZ-Script and defined on a per project basis, there would be no version control and outdated/bugger functions would be difficult to manage across projects.
I'll think a bit on what an EZ-Script user function with online version management simlar to a plugin would look like. hmmm...
While we're on the topic... (and assuming I got the gist of this function idea).... A function or library for serial would be great... I am just ok at serial stuff, but streamlining serial receive would be welcome...
@Richard R,
Can you elaborate.
#15
@PTP.... I would like to just read serial into a variable in a function call... avoiding GetByteAt, UARTAvailable, UARTRead, etc....
And maybe even a simple parser... $string=(left($string),10,5) Something like this would set $string as the 10th character in and read for 5 characters after.... This way you can pick the data you want out of the incoming serial data
#16
How would you know if any data had been transmitted, how to tell if a packet had been received without UartAvailable()?
Why are you ever GetByteAt() anyway? That's not a serial specific function - it's a function to get a byte(character) within a string
