Darknet YOLO (Obj Detection) icon Darknet YOLO (Obj Detection) — Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores. Try it →
Dc Motor Position Control
Hello,
If I have a set of DC motors with encoders already soldered with the intentions of obtaining position control instead of continuous rotation. would I still need to run an H-bridge or can I hook the dc motors with encoders directly to the ez-b without and h-bridge and get the results I am looking for?
Thanks in advance.
You always need an hbridge for motors and high current items. The EZ-B will be damaged it you connect it to a motor directly. If you're using encoders, the kangaroo and sabertooth are the best.
DJ Sures
Thank you for the reply. I Am Attaching The Link For The Motors I Want To Use Just To Make Sure They Will Work With The EZB and H-bridge. They are a cheap Chinese brand however for what I need them for they are perfect. Also did I read correctly that 1 h-bridge will power 2 motors so I would need 3 h bridges for the 5 motors or did I misunderstand that part?
m.aliexpress.com/item/32615361964.html?trace=wwwdetail2mobilesitedetail&productId=32615361964&productSubject=Well-made-GA12-N20-dc-gear-motor-with-encoder-speed-velocity-measurement-6V-500rpm-FOR-mini
