The Navigator icon The Navigator — Path-planning navigator using ARC NMS position and obstacle data to map, log trajectories, and autonomously follow waypoints. Try it →
Debouncing Darknet YOLO on TurtleBot3
Debouncing Darknet YOLO On Turtlebot3
Running ARC on a TurtleBot3 Burger with an Intel NUC (Windows) on the base, USB to OpenCR for motor control, and a Logitech C920 as the camera. I’ve added Camera Device at 640x480 and the Darknet YOLO (Obj Detection) skill. With Running enabled, the On Changes script fires many times per second even when a person is standing still. I think tiny score fluctuations are triggering changes, which spams my Audio.say and any movement logic. CPU also jumps when I leave YOLO in continuous mode.
I tried switching to on-demand detection with a JavaScript loop and that helps CPU, but I still get chatty events due to score changes. My current approach is to threshold and require N consecutive frames before acting:
// On Changes script
var n = getVar('$YOLONumberOfRegions');
var classes = getVar('$YOLOClasses');
var scores = getVar('$YOLOScores');
var target = 'person';
var thresh = 0.6;
var count = getVar('$personCount') || 0;
var seen = false;
for (var i = 0; i < n; i++) {
  if (classes[i] === target && scores[i] >= thresh) { seen = true; break; }
count = seen ? count + 1 : 0;
setVar('$personCount', count);
if (count === 3 && !getVar('$personAnnounced')) {
  setVar('$personAnnounced', true);
  Audio.say('Person detected');
if (!seen) setVar('$personAnnounced', false);
And my on-demand loop:
while (true) {
  controlCommand('Darknet YOLO', 'Run');
  sleep(500); // 2 Hz
Is this the right pattern for TurtleBot3, or is there a better way to throttle/filter Darknet YOLO (Obj Detection) so On Changes doesn’t fire on minor score wiggles-e.g., recommended confidence thresholds, built-in options, or a more robust debounce strategy?
Turtlebot 3 by Robotis
Program TurtleBot 3 with Synthiam ARCx or ARC: ROS 2 bridge, browser control, Blockly, Python, lidar, RealSense and robot skills
Servos 200
UART Varies
ADC Varies
Digital Varies
Script by Synthiam
Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores.
Yes - your debounce/state-machine approach is the right direction for ARC and TurtleBot3. Darknet YOLO will often emit small score/box fluctuations even when the scene looks "unchanged," so if you react to every On Changes event directly, you’ll get chatter.
What I’d recommend
1) Treat YOLO as a sensor stream, not an event
Instead of "fire action immediately," use:
  • confidence threshold
  • consecutive-frame confirmation
  • cooldown / hysteresis
  • state change only
That means:
  • only declare "person present" after a person is seen N times in a row
  • only clear the state after the person is missing for M times in a row
  • optionally enforce a cooldown so Audio.say can’t repeat too quickly
2) Your current script has one logic issue
This line:
will only fire on the exact frame where count becomes 3. That’s fine, but if your detections bounce around, you may want >= 3 instead. Also, your !getVar(...) check is risky if the variable has never been initialized.
A more robust pattern is to track a stable state and separate seen vs not seen counters.
3) Better debounce pattern for On Changes
Try this JavaScript in the YOLO On Changes script:
var thresh = 0.6;
var seen = false;
  if (classes[i] == target && scores[i] >= thresh) {
    seen = true;
    break;
var seenCount = getVar('$personSeenCount', 0);
var missingCount = getVar('$personMissingCount', 0);
var personPresent = getVar('$personPresent', false);
if (seen) {
  seenCount++;
  missingCount = 0;
} else {
  missingCount++;
  seenCount = 0;
setVar('$personSeenCount', seenCount);
setVar('$personMissingCount', missingCount);
// Require 3 consecutive positive frames to enter the state
if (!personPresent && seenCount >= 3) {
  setVar('$personPresent', true);
// Require 5 consecutive negative frames to leave the state
if (personPresent && missingCount >= 5) {
  setVar('$personPresent', false);
  Audio.say('Person lost');
Why this works better
  • avoids repeated speech on minor score wiggles
  • tolerates one or two missed frames
  • changes state only when the detection is stable
4) Add a cooldown for speech
Even with state logic, I’d still add a cooldown so Audio.say() can’t spam if the scene flips rapidly.
var now = new Date().getTime();
var lastSpeak = getVar('$lastPersonSpeak', 0);
if (now - lastSpeak > 3000) {
  setVar('$lastPersonSpeak', now);
You can combine that with the stable-state code above.
5) About the on-demand loop
This part is fine in principle:
while (true) {
  sleep(500);
But I’d suggest:
  • don’t run it faster than needed
  • start around 500-1000 ms
  • stop the loop when your mode changes
  • consider using a script state variable like $mode
Also, if you only need person detection occasionally, running YOLO at 1-2 Hz is usually much gentler on CPU than continuous running.
6) Even better: use a single "person stable" branch
A clean pattern in ARC is:
  • YOLO On Changes updates detection variables
  • another script reads those variables every 200-500 ms and makes decisions
That separates:
  • vision ingestion
  • robot behavior
This often makes debugging much easier.
7) About built-in YOLO options
Darknet YOLO in ARC does support running from the camera and reacting on changes, but the main practical filtering is usually done in script rather than relying on a special built-in "debounce" feature.
So the best tools are:
  • consecutive-frame count
  • cooldown timer
  • state variable ($personPresent)
  • optional missing-frame grace period
8) TurtleBot3-specific note
Because you’re on a TurtleBot3 Burger with a C920 and an Intel NUC, CPU load is expected to jump when YOLO is continuous. Your move to on-demand is the right direction.
For TurtleBot3 projects, I’d usually recommend:
  • keep YOLO off unless needed
  • trigger it at a controlled rate
  • use the OpenCR for motion only
  • avoid tying movement directly to every detection event
9) Suggested ARC project structure
A solid setup would be:
  • Camera Device
  • Darknet YOLO
  • Script skill for debouncing/behavior
  • Movement Panel for TurtleBot3 control
  • optional Sound skill if you want separate audio control
If you want, I can help you turn this into a cleaner state machine script for:
  • idle
  • searching
  • person_detected
  • approach
  • lost_target
That’s often a much better fit than reacting to every YOLO callback.
10) ARC AI Script Assistant tip
If you’re editing this inside ARC, the AI Script Assistant can rewrite the script directly in the editor and adapt it to your exact skill names and variables: https://synthiam.com/Products/AI-Assistant
If you want, I can also give you a complete TurtleBot3-ready YOLO debounce script in JavaScript that includes:
  • hysteresis
  • cooldown
  • stable detection
  • stop/move behavior based on person presence
