Roll Pitch Yaw icon Roll Pitch Yaw — Rotate and position camera or object with roll/pitch/yaw controls; save camera settings; bind or monitor a 3-value EZ-Script array for live rotation. Try it →
Define And Append Array
Could someone have a look at "Define and Append array" under EZ-Script Function syntax in ARC Example Both examples are giving error syntax.
No matter how long it takes to get the hardware, there is plenty to do with ARC to develop 40 years dormant ideas.
First, are you running the latest version of ARC? There was a bug in the array function until recently.
I'm not home right now but if nobody else has jumped on it I'll take a look when I get home.
Tank's Rich for the quick response
I am using version 2014-03-08-00
All I know is "AppendArray" function have been replace with "FillArray"
Sounds like the example wasn't updated - i'll look into that right away! thanks for the update:D
