EZ Gauge Chart icon EZ Gauge Chart — Dashboard-style configurable gauge chart with red-zone indicator, adjustable range/arc, scale ticks, title and live value updates. Try it →
Netherlands
Twitter YouTube
Hi @Nomad,
What exact device model are you using?
What's the distance between the engenius and your EZ-B?
Can you see other access points through the engenius adapter?
I have used an engenius USB network adapter in the past and it worked just fine.
If it's a router, does that mean you bought a new one?
Netherlands
Twitter YouTube
@Richard
I assumed he was talking about a network adapter for his PC, just found out Engenius also makes access points.
@Nomad
If you mean an access point, did you reset the EZ-B and reconnect it to the access point? Again, what's the model number? It might be a 5GHz AP.
Thanks @Niek.... @nomad are you sure you want to be messing with network stuff again?... :P
its an accses point engenius 300 repeater. its in close range whit ezb some 4 meters. on my android it says for bolt ezb-4 not visseble. the engenius is connected,so i figur some is wrong on the accses page, from engenius.but i cant find that page.
accses point
rr i cant use my android if i dont get it fixed,
If your ezb is in Client mode it won't show up in your wifi list.... The ezb has to be in WP mode for this...
@Nomad, why did you change your set up? It took a long time and a lot of posts to get it sorted out the first time!
If it's not being found then it isn't broadcasting. However if you are looking for an EZ-B with a router then you're going to have problems over and over again.
  1. Reset everything.
  2. Follow all steps that you followed when you first set it all up (presumably you recorded what you needed to do in the case of a problem, right?..)
  3. Ask Mr Cochran politely to set it up for you again.
  4. Don't touch it once it's fixed!
