Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Germany
Dfferent Servo Speed - Same Settings
hi there..
I use the Auto Position app to control my robot. my action settings for "turn left" and "turn right" (all frames) are:
15 1 -1
but turn left is more fast as turn right.. sometimes.. I change settings from "go forward "or add a new action.. after that all other actions are faster then before.. I dont know why.. ?!
same problem with the camera tracking speed.. the horizontal is slower then the vertical speed.. both are the same ez-robot servos.. both use 4 steps..
Can I set all servos to a same speedlevel ?
thanks
What robof or configuration are you using?
All servos of the same manufacture and model should be the same speed - specifically ezrobot servos. And the Auto Position ensures that all servos arrive to their destination position at the same time. It's impossible for that to not happen.
  1. Please explain your robot and it's configuration for assistance.
  2. Also, it doesn't sound like you read the blue question marks or the Auto Position manual page on what the "speed" option does.
  3. Lastly, where are you adjusting the "speed" value?
Most important question is #1.
