Blinkm icon Blinkm — BlinkM I2C multi-color LED control with slide dials for custom colors; supports SendI2C for custom I2C peripherals. Third-party device. Try it →
DialogFlow driving Sphero reliably
Dialogflow Driving Sphero Reliably
I’ve got a Sphero (SPRK+) paired over Bluetooth and the Sphero Movement Panel works great for manual driving. I’m now layering in the DialogFlow robot skill so I can say things like "forward for two seconds" or "spin left for one second" and have ARC handle timed moves.
Setup details:
  • DialogFlow skill is configured with my Google service account JSON and returns intents correctly in its console.
  • I’m using ARC’s Speech Recognition to capture voice to $Speech, then sending it to DialogFlow with:
ControlCommand("DialogFlow", "Send", $Speech)
  • In the DialogFlow skill, I’m using the "Script to Execute On Response" to read the global vars it publishes (intent name and parameters) and call Movement Panel commands. The plan is basically: Stop(), set speed, Forward()/Left(), Sleep(durationMs), Stop().
What I’m running into:
  1. Occasionally the On Response script fires twice for a single utterance, so Sphero repeats the same move back-to-back.
  2. If I use DialogFlow’s @sys.duration, the parameter often comes through as a string like "2s" or "2.0 sec", which makes Sleep() math messy. Switching to @sys.number helps, but then I lose units and must hardcode seconds.
  3. Network round-trip adds ~500-1500 ms before the command executes; during that delay Sphero may continue a prior motion. Prepending Stop() helps but causes a visible jerk.
Is there a recommended ARC pattern or sample project for consuming DialogFlow intents in the On Response script to drive the Sphero Movement Panel with precise, time-limited moves, including debouncing duplicate triggers and reliably parsing numeric parameters?
Sphero by Sphero
Drive Sphero from Synthiam ARC with Bluetooth, voice control, scripts, chatbot skills and more on Windows 10/11.
Bluetooth
Servos ✕
ADC ✕
Digital ✕
Dialogflow by Google
Add Google DialogFlow NLP to ARC: conversational intents, parameter prompts, scripted responses, service-account setup and programmatic robot control.
Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots.
Yes - the most reliable pattern in ARC is to treat DialogFlow as an intent parser only, then have a small script layer do the movement in a controlled way.
1) Use a numeric parameter, not @sys.duration
For timed motion, I recommend:
  • @sys.number for the amount
  • a separate entity or slot for the unit if you want "seconds" vs "milliseconds"
That avoids DialogFlow returning mixed strings like "2s" or "2.0 sec".
If you only care about seconds, just use @sys.number and interpret it as seconds in your ARC script.
2) Debounce duplicate DialogFlow responses
If the On Response script is firing twice, add a simple guard variable in ARC.
Example pattern:
var now = new Date().getTime();
var last = parseInt(getVar("$LastDialogFlowMs", "0"));
if ((now - last) < 400) {
  print("Ignoring duplicate DialogFlow response");
  return;
setVar("$LastDialogFlowMs", now.toString());
That will ignore repeats within 400 ms.
You can adjust the window if needed.
3) Move first, stop only once, and avoid extra stop calls
For Sphero, a clean sequence is:
  • set speed
  • start movement
  • sleep for the requested time
  • stop
If you’re seeing a jerk from a pre-stop, that’s usually because the robot is already moving and then gets interrupted. In most cases, it’s better to only stop once at the end unless you are intentionally canceling an in-progress command.
Example ARC script for DialogFlow response
This assumes:
  • $APIIntent contains the intent name
  • $APIComplete is true when fulfillment is complete
  • $APIParameters[0] = direction
  • $APIParameters[1] = number of seconds
var intent = getVar("$APIIntent");
var complete = getVar("$APIComplete");
if (intent != "move.direction.time") {
  return;
if (!complete) {
  print(getVar("$APIResponse"));
  return;
// Debounce duplicate callbacks
  print("Duplicate intent ignored");
  return;
var direction = getVar("$APIParameters[0]").toLowerCase();
var seconds = parseFloat(getVar("$APIParameters[1]"));
if (isNaN(seconds) || seconds <= 0) {
  print("Invalid time parameter");
  return;
var ms = Math.round(seconds * 1000);
print("Direction: " + direction + ", time: " + ms + "ms");
Movement.stop();
sleep(100);
if (direction == "forward") {
  Movement.forward();
} else if (direction == "reverse") {
  Movement.reverse();
} else if (direction == "left") {
  Movement.left();
} else if (direction == "right") {
  Movement.right();
} else {
  print("Unsupported direction: " + direction);
  Movement.stop();
  return;
sleep(ms);
Movement.stop();
For spin left / spin right
If you want "spin left for one second", I’d suggest making a separate intent like:
  • spin.direction.time
Then map:
  • "left" -> Movement.left()
  • "right" -> Movement.right()
If your Sphero movement skill has a specific "spin" behavior exposed through its movement panel, use that command instead. Otherwise, the left/right turn logic above is usually the simplest ARC pattern.
About the latency
That 500-1500 ms round-trip is normal when you wait on the cloud intent result. A few ways to reduce the impact:
  1. Use DialogFlow only to determine intent
  2. Keep the Sphero motion logic entirely local in ARC
  3. Avoid extra waits in the script
  4. Use a short debounce window
  5. If you need near-instant response, consider using Speech Recognition directly to script for the most common commands and reserve DialogFlow for more flexible phrases
That last option is often the best user experience:
  • Speech Recognition for fast commands like forward/stop/left/right
  • DialogFlow for more complex conversation or ambiguous phrases
Best practice for parsing parameters
If you want robust numeric parsing, do this:
var raw = getVar("$APIParameters[1]");
var seconds = parseFloat(raw);
If you ever do want to support strings like "2 sec" or "2.5 seconds", you can strip text first:
var raw = getVar("$APIParameters[1]").toLowerCase();
raw = raw.replace("seconds", "");
raw = raw.replace("second", "");
raw = raw.replace("sec", "");
raw = raw.trim();
But again, @sys.number is cleaner.
ARC config tip
You can place this script in the DialogFlow skill’s config menu:
  1. Open the kebab menu / three lines on the DialogFlow skill
  2. Choose Config
  3. Edit the Script to Execute On Response
That keeps the parsing and movement logic in one place.
Helpful references
My recommendation for your project
For reliability, I’d use this structure:
  • Speech Recognition captures phrase
  • ControlCommand("DialogFlow", "Send", phrase)
  • DialogFlow returns only the intent/parameters
  • ARC script:
    • debounces
    • validates intent
    • parses numeric seconds
    • issues one movement command
    • sleeps locally
    • stops once
If you want, I can help you write a clean DialogFlow intent handler for:
  • forward for two seconds
  • reverse for three seconds
  • spin left for one second
  • stop
with a single reusable ARC JavaScript script.
