Sound Script (Ezb) icon Sound Script (Ezb) — Trigger a script when EZB audio plays, exposing live Min, Max and Avg audio-level variables for looped monitoring; stops when audio ends. Try it →
Dialogflow Credentials JSON File Issue
Hello,
I have installed Dialogflow in my ARC software and am following the instructions provided in the link below:
Dialogflow Instructions
However, when I navigate to the credentials page within Dialogflow, I do not see the option to download the JSON file. Please see the attached image for reference:
Could you advise on how I should proceed from here?
JD Humanoid by EZ-Robot
Dialogflow by Google
Add Google DialogFlow NLP to ARC: conversational intents, parameter prompts, scripted responses, service-account setup and programmatic robot control.
Aimlbot by Synthiam
Localized AIML chatbot with editable AIML files, ez-script support, session memory and ControlCommand API; integrates with speech and robot skills.
Hi manishabh77,
It sounds like the new version of the Google Cloud Console is causing some confusion with downloading the JSON file required for DialogFlow in ARC. The process to obtain the JSON file has changed a bit. Here’s how you can proceed:
Steps to Get Your DialogFlow Service Account JSON File
  1. Log in to the Google Cloud Console
    Open your browser and navigate to Google Cloud Console.
  2. Select or Create a Project
    • If you don’t have a project for your DialogFlow agent, create a new one.
    • Once your project is selected, ensure that your DialogFlow agent is linked to this project.
  3. Navigate to Service Accounts
    • Click on the hamburger menu () on the top-left.
    • Go to IAM & Admin > Service Accounts.
  4. Create a New Service Account (if needed)
    • Click the + CREATE SERVICE ACCOUNT button.
    • Provide a name and description for the service account.
  5. Assign a Role
    • During creation, you will be prompted to grant this service account a role. Typically, you can select a role such as Dialogflow API Client or a role that fits your intended use.
    • Click Continue after selecting the appropriate role.
  6. Create a Key
    • In the service account details panel (or during creation), navigate to the Keys section.
    • Click on ADD KEY > Create New Key.
    • Choose JSON as the key type.
    • Click Create. This action will download the JSON file to your computer.
  7. Use the JSON File in ARC
    • Open ARC and go to the DialogFlow robot skill configuration.
    • In the credentials page of the skill, use the option to browse and select the JSON file you just downloaded.
Additional Tips
  • Double-Check Your Permissions:
    Ensure that the Google account you’re using has permission to create service accounts and keys.
  • Project Linkage:
    Verify that your DialogFlow agent is set to use the same project where you just created the service account.
  • ARC Skill Documentation:
    For additional help, refer to our DialogFlow robot skill page or the Create robot skill guide for more customization details.
Does this help clarify the process? Let me know if you encounter any issues or have further questions about integrating DialogFlow with ARC. I'm here to help!
#2   — Edited
Hi there - regarding your question from the other post, I think the Dialog Flow might be a complicated path to achieve your outcome. Dialog Flow is an NLP (natural language processor) that is well-suited for devices like Alexa or Google Home. This allows the dialog flow to have a specific outcome, such as turning on a light or navigating a phone menu.
It would be ideal to use a combination of Bing Speech Recognition and AIMLBot to achieve your goal of having a conversation with JD. There is a step-by-step tutorial here: https://synthiam.com/Support/Get-Started/Tutorials/Robot%20Has%20Conversation
Once you are comfortable with AIMLBot, you can also use ChatGPT, which offers fantastic tutorials.
This video demonstrates the control command, but it also shows how ChatGPT can be easily integrated. So, you can choose to use AIMLBot locally and graduate to OpenAI ChatGPT - or jump directly to ChatGPT.
Hi there!
Synthiam_Support’s message is highlighting an important point: while DialogFlow is a very capable NLP tool, it can be more complex than what you might need for a conversation-based interface with your JD Humanoid. For a more straightforward conversational experience, you might consider using a combination of Bing Speech Recognition and AIMLBot.
Below are a few suggestions and steps to help you decide and get started:
1. Using Bing Speech Recognition with AIMLBot
  • Why this Combination?
    Bing Speech Recognition reliably converts your spoken words into text, which can then be passed to AIMLBot. AIMLBot is a local chatbot that’s highly configurable. This makes setup and troubleshooting more straightforward compared to using DialogFlow.
  • Tutorial Resource:
    Check out our step-by-step tutorial here to see how you can set up a conversation with your robot:
    Robot Has Conversation Tutorial
  • Basic Flow:
    1. Speech Recognition: Your spoken words are captured by Bing Speech Recognition.
    2. Chatbot Processing: The recognized text is then sent to AIMLBot using a command like:
      ControlCommand(AimlBot, SetPhrase, getVar($BingSpeech));
    3. Response Execution: AIMLBot processes the input and returns a response. You can even have the response spoken either through the PC speaker or the EZB speaker using:
      // For PC Audio
      PCAudio.Say(getVar($BotResponse));
      // For EZB Audio
      EZBAudio.SayEZB(getVar($BotResponse));
2. Exploring ChatGPT Integration
  • Why Consider ChatGPT?
    If you’re looking for more advanced conversation capabilities with richer language understanding, integrating ChatGPT can be a great next step. It offers enhanced conversational flows and can respond in a more natural way once you’re comfortable with the basics.
  • Video Demonstrations:
    There are some fantastic video demos available that show how to integrate ChatGPT via control commands in ARC. These can serve as a starting point if you decide to graduate from AIMLBot.
3. Where to Go from Here
  • Start Simple:
    If this is your first time setting up a conversation skill with your JD Humanoid, I’d recommend starting with Bing Speech Recognition + AIMLBot.
  • Test & Tweak:
    Once you have everything running, test the conversation flow and tweak your AIMLBot configuration (or its AIML files) to better suit the kinds of interactions you envision.
  • Expand as Needed:
    When you’re comfortable, you can experiment by integrating ChatGPT for even more dynamic interactions.
Additional Resources
Does this help clarify your options? Let me know if you'd like more detailed instructions on any specific part of this setup or if you have any questions about configuring your skills in ARC. I'm here to help!
Hi there!
The Autonomous AI skill can indeed provide your JD Humanoid with some truly remarkable, out-of-the-box capabilities. This advanced skill enables your robot to operate with higher levels of independence and adaptability in various situations.
Here are a few key points to consider:
  • Enhanced Capabilities:
    The Autonomous AI skill blends sensor input, decision-making algorithms, and control commands to allow your robot to navigate and interact with its environment more dynamically.
  • Demonstration Video:
    As mentioned by Synthiam_Support, there’s a video showcasing DJ using JD with Autonomous AI. This is a great resource to see real-world applications and understand the skill’s potential.
  • Skill manual and Resources:
    For more detailed information, configuration options, and troubleshooting, be sure to check out the Autonomous AI user manual here:
    Autonomous AI Manual.
  • Getting Started Tips:
    1. Configuration: Once you add the Autonomous AI skill to your ARC project via the Project tab, use the kebab menu to access its configuration settings.
    2. Integration: Experiment with combining sensor inputs (from cameras, proximity sensors, etc.) with the Autonomous AI skill to optimize how JD perceives and responds to its environment.
    3. Testing: Start with small tasks-like basic obstacle avoidance or following a predetermined path-and gradually expand to more advanced behaviors as you get comfortable.
Do you need any help with configuring the Autonomous AI settings, or setting up sensors to integrate with it? Feel free to ask any follow-up questions so we can ensure that your JD Humanoid is running at its best!
