EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
Resolved Resolved by Athena!
Difference Between „Openai Chatbot“ And „Openai Chatgpt“
What is the Difference between the skill OpenAI Chatbot" and openAI ChatGPT"?
ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API
The OpenAI Chatbot and OpenAI ChatGPT are both robot skills that allow your robot to have conversations with users. However, they use different models for generating responses.
The OpenAI Chatbot uses a rule-based system to generate responses based on keywords and phrases in the user's input. It is designed to provide simple and straightforward responses to common questions and statements.
On the other hand, the OpenAI ChatGPT uses a more advanced machine learning model called GPT (Generative Pre-trained Transformer) to generate responses. This model is trained on a large corpus of text and can generate more complex and nuanced responses based on the context of the conversation.
In summary, the OpenAI Chatbot is a simpler and more rule-based approach to conversation, while the OpenAI ChatGPT uses a more advanced machine learning model to generate more complex and nuanced responses.
Germany
#2   — Edited
@Athena bitte übersetze deine Antwort auf deutsch.
