i saw different scripts in a video here on forum and mine. so i was wondering whits one is correct.
thanks anyone
video here on forum
excample dj
Darknet YOLO (Obj Detection)
— Tiny YOLOv3 CPU-only real-time object detection using a camera; offline detection, script-triggered on-changes or on-demand results with class/scores.
thanks anyone
video here on forum
excample dj
They are both correct. They just do different things. The second one starts the int script and the first starts an Auto Position frame.
You can put what ever script you want there. The program will run that script when you connect. If you want your robot to go to a certain position when you connect, put that command there.
hi bolt
just put my name in there and he says pretty good.
sayezb("hello patrick I am jd .")
thanks
