Please write your question in Russian language. Maybe we can translate better.
Russia
I changed on a hand Standard servo on digital (180 degrees, 25 kg/cm), not always work, it is need to power switch off and after on (power external) - then works. It's connected in D1. digital servo need to program? Or change to a standard?
I think it would be good practice if you change any hardware on the EZ-B to power it off 1st. A digital servo should work just as well as a standard one however there isn't many comments from peeps on these forums that have tried a digital one that I can remember.
No doubt others will pop on and comment
Can you post the model and a picture of your servo. I can check if it is programmable. Anytime with electronics it is a good idea to power your equipment off before making changes.
