Translate icon Translate — Translate text via Microsoft Translator (auto-detect); EZ-B plugin stores translated and detected language variables. Requires Azure key. Try it →
rr
iff i not mistaken i did read not to drop the batt below 6.6 volts
#50
No, that's the low voltage warning for the Lipo battery...If you drain a lipo battery below 6.6V it will be ruined... The ezb's board (logic part part of it) works on 5V like virtually all other logic devices. If the ezb's voltage drops below 5V it will reset...
I run my ezb from a 6V SLA battery with no issues at all... I set the low battery warning to 5.5v instead of 6.6 (which I would use if I was using a 7.4V Lipo)...
rr
yes thats what i mean
