Display Popup Timeout Not Working
@DJ.
When using the display popup plugin, the default timeout works great (as demonstrated at the start of my Showcase video, but when using the control commandant adding the timeout to the end of the command, the timeout I set in the command doesn't seem to work and the display stays on the screen until I hit exit. Have you noticed anything with this?
Thanks.
The timeout is in Seconds not Milliseconds
Ahh, that'll be it. My bad.
Thanks.
