Dual-Axis Compass icon Dual-Axis Compass — Dual-axis I2C magnetic sensor for EZ-B robots enabling magnetic direction sensing; requires short 2-3 in wiring. Third-party hardware. Try it →
Diy Attempt To Make Ar Drone 2.0 Ez-Robot Compatible
Well. I'm actually trying. So. Because the ar drone 2.0 is not compatible with ARC , I decided to try to do it myself. Right now, the Movement Panel for the ar drone 1.0 works with my 2.0, but I cant see the camera.
So here's what I've come up with:
1.Mounting ez-b V4 with camera on ar drone(somewhat straight forward)
Or
2.Find a way to connect to the camera via a different program and relay it to ARC either via http or by using a program that will make the camera feed a system device.(anyone who can find this kind of program I will give all credit to)
Anyone who has comments is welcome to comment. If you have ideas or you already have a ar drone 2.0 with the camera working in ARC somehow PLEASE TELL US HOW!
Thank you for any comments that appear.
Now lets get those Ar drone 2.0's flying!
#17
tried tcp://192.168.1.1:5555 in VLC media player and it worked(!) but it was laggy and jumpy.
#18
hmm ok so we are making progress! Sorry im trying to help just not having it in front of me I am having to imagine everything:)
Are there any settings on the ffmpeg app athat you can set a frame rate?
#19
like I said, I can't open the ffplay, ffmpeg, etc. it flashes the cmd prompt and I cant read anything on it when it flashes. One thing is that ive connected to it with the ar drone 1 control before I tried to connect.
No problem man. I can imagine we're both somewhat tired. This weekend will be a good time to make big progress on this project.
#20
Its late but i still wanna see this work lol. OK so VLC player is what your using and you used the TCP address i gave you.
#21
yes. plus I have connected to the ar drone through ARC.
#22
ok. with the tcp address was ez builder able to see the video feed, its just choppy?
#23
No. Have not tested it with ARC. Movement Panel was connected to drone.
Connecting to ARC camera is my next task. ARC accepts codecs in the camera control. Get a h.264 codec in there and your able to connect I bet.
#24
Probably yea ,hmm I wonder what style / codec ARC uses and we can try to find one.
