Connection Diagnostic icon Connection Diagnostic — Diagnose EZ-B Wi-Fi connection issues with verbose EZ-B communication logging, ping tests, log export and diagnostic reports for Synthiam support. Try it →
Diy Camera / Phone Tripod From Instamorph / Polymorph Plastic
https://synthiam.com/Shop/AccessoriesDetails.aspx?prevCat=8&productNumber=28
The Polymorphic Thermoplastic is available in 1kg variety in the store for 40 dollars. I linked it above. I would recommend everyone who buys a EZ Robot kit to get a bag of this stuff because you can use it literally on every project. It's just as useful as hot glue , epoxy or solder.
I needed to make a stand fore close up lighting when soldering and using the new HD camera. A few grams was plenty to shape a tripod by hand. I will upload videos once I edit them. I did 4 videos while molding the stand. Once you have the shapes you want you must "Shock" the polymer with cold water. The colder the better but for this video I used cold running water to lock in the shape. It would be excellent for making little brackets and servo connections.
lol, who needs a 3-D printer.
Lol ,I know right? I will do another tutorial later showing you can use thermoplastic to make a mold , then fill with resin or more plastic then pop out the duplicated part.
I was thinking of getting instamorph. It's pretty cool!
Speaking of , I know the instructions say all it takes is 140 degrees to get that stuff moldable but it seems to take forever for it to start softening and turn clear. I have to turn the heat up to 160-180 degrees if I want it maliable in a few min.
