Do I need an init script?? the servos seem to go to extremes on initial run..
edbot
— Edited
4 Participants
Kondo KRS ICS Servos
— Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands.
Can you provide more details?
Hi edbot, Are you loading the correct app for the robot?
Yeah let's find out how we can get you up and running
thanks ,
I uploaded a video of the initscript startup on connection. ( I think?? Not sure if the video is here)
I have also uploaded my project to the cloud, so hopefully you can see what the problem is .
Hi Edbot,
I don't see the project or the video you mentioned. It's probably not you. There's a few gremlins on this new forum right now.
It's been my experience that running an int script when your project starts is a wonderful way to set servo speeds, servo min/max ranges, positions, set variables and tons of other needed things to make your project run.
Good luck and have fun.
Trouble with the site ..... I keep getting: Error submitting the comment. Comment too short for submission. when I try to post but this is the issue with my InitScript
RE3D12_14_18.EZB
hopefully this helps to understand my issue
Well, that's one interesting robot. Kinda reminds me of Road Warrior. Very cool and imaginative. I love it!
I wish I could find your project you saved to the cloud. That could help me see what's going on with your script.
Looks like you have a wrong position command in your script or an improperly calibrated servo there.
Can you move the servo properly with a servo control in ARC. If it moves erratically like that when you use the slider in the control then you may have a bad pot in the servo.
I like your color scheme and angry temperament! Looks like a movie clip of an evil Inmoov trying to escape something.
That doesn't help your problem, I know.
