Dual-Axis Compass icon Dual-Axis Compass — Dual-axis I2C magnetic sensor for EZ-B robots enabling magnetic direction sensing; requires short 2-3 in wiring. Third-party hardware. Try it →
#17
JOSH you read the specs on VU meter it says you can set the voltage,vu meter measures volume of audio and apply to leds ,more the sound pressure more the leds turns on like a persons mouth.
PWM is just mostly a flasher that does only one led per pwm output,witch for eyes it works well. MOSFET works better then a transistor because is variable resistor depending on the voltage apply.
