Ez Line Chart icon Ez Line Chart — 4-series historical line chart to log and compare robot sensor values over time with customizable titles, colors, time axis and EZ-Script control Try it →
Hmmmmm - I haven't tried mine above 6V
There is a servo tester going around? Neat, I have wanted to get one, perhaps if I don't wear my toque I will catch it:P
:) All humor aside... this looks like one I was considering ordering. I would think the issue would be more the servo limitations than the tester... at least within reasonable voltages. What I have read says that "in general" servos should not be feed more then 5v. That said, some may take more than others... I doubt this tester regulates the incoming voltage but you could test that with a meter before plugging in a servo.
Standards servos run 6v and high torque 7.4 volts. 7.4 vvolts could run your servos hot if they aren't made for it.
OK, Thanks, Guys. I do have two high torque ones I need to test. They are brand new and when i hooked them up to the EZB, the fuse blew. So, I want to check them with the little tester B4 I hook them up to the EZB. Make sense?
Josh, you have so many creative juices, I am standing over here in Nashville trying to catch some of the spill-over. You are the closest EZB guy near me.
Thanks,
Mel
