Servo Speed icon Servo Speed — Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved. Try it →
Sweden
Does Ez-b Support This Motor Controller?
Does Ez-B Support This Motor Controller?
Hello!
First off, I'm a programmer but I'm new to electronics and hardware so I don't really know much about the compatibility between different cards and circuits. If someone could recommend some reading material to learn this stuff I would be very happy!
I would gladly buy your motor controller, but the shipping costs are killing me since I live in Sweden.
And if i got anyone's attention I would still like an answer to this other question I asked a while ago: https://synthiam.com/Community/Questions/945
This is the specifications: Dual Motor L298 H-Bridge Control kit can control two DC motors connected to it. This kit uses the famous industry standard L298 H-Bridge IC.
  • Motor supply : 7 to 46 VDC
  • Control Logic Supply : Standard TTL logic level
  • Output DC drive to motor : upto 2 A each
  • Current Sense Output available
  • Onboard resistor provided for current reading
  • Enable and direction control pins available
  • External diode bridge provided for output
  • Heatsink for IC
  • Power-On LED indicator
  • Power Battery Terminal (PBT) for easy input (PWR) / output (Motor) connection
  • Four mounting holes of 3.2 mm each
  • PCB dimensions 61 mm x 63 mm
Also, see attached image.
EDIT: You actually have to press upload, ooooops!
Thank you!
// Tobias
