Continuous Servo Movement Panel icon Continuous Servo Movement Panel — Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options. Try it →
Netherlands
Does anyone have a Cytron Smartdrive Duo 30 and what are the diffrences?
Does Anyone Have A Cytron Smartdrive Duo 30 And What Are The Diffrences?
Does anyone have a Cytron Smartdrive Duo 30 and what are the diffrences with a sabertooth in settings?
https://www.cytron.io/p-30amp-7v-35v-smartdrive-dc-motor-driver-2-channels
Folowing the manual and comparing it... I came to these settings... Still have to test it... But maybe someone has some conformation?:)
Stop
SendSerial(D0,9600,0) SendSerial(D0,9600,128)
Forward
Motor 1, 63 is full speed forward.
SendSerial(D0,9600,63)
Motor 2, 191 is full speed forward.
SendSerial(D0,9600,191)
Differential Turn Right
Motor 1
Motor 2
SendSerial(D0,9600,255)
Differential Turn Left
Motor 1
SendSerial(D0,9600,127)
Motor 2
Reverse
Motor 1, 127 is full speed reverse.
Motor 2, 255 full speed reverse.
And what about the Speed Changed setting?
Sabertooth Movement Panel by Dimension Engineering
Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options.
The commands look right - but you'd have to test.
If you want speed control, there's two ways to go about it
  1. Create a skill control
  2. Use a custom movement panel
If you choose #2, there's a $speedleft and $speedright variable which you can use. You'd have to use a little math to determine the speed for each direction.
Netherlands
It has been a long time, but i am back on this project;)
So i have made a custom movement panel. Everything works...  But it's just one speed...   i managed to found out if i set lower numbers in the script the speed will be lower...  But the 2 shuffles for speed won't work.
Would be nice if the sabertooth script was editable or viewable so i can compare;)
I found Gwen's question... about "ramping" As i understood this was to build up te speed instead of only 1 speed that stops abrubtly (https://synthiam.com/Community/Questions/Movement-Scripting-Help-Please-2983)
I loaded the latest script and changed some perimeters to be compatible with this controller. But it doesn't seem to work for me...
Netherlands
I think my problem is...  Where the sabertooth increases the speed from a stop. 0-10-9-8-7-6-4-3-2-1-0-1-2-3-4-5-6-7-8-9-10 The Smartdrive Duo increases otherwise 0-1-2-3-4-5-6-7-8-9-10-0-1-2-3-4-5-6-7-8-9-1-0
example smartdrive duo
vs Sabertooth
Netherlands
Thanks for the fast response:) I was reallly mindboggling about what to do.
Going to try that and let you know my results. But if i look at the manual that should do the trick:) THANKS!
They did all the planning for you ahead of time it seems. It makes most sense to re-use the continuous rotation Movement Panel since it's created for this use-case...
Netherlands
It works! THANKS! I only need to adjust the speeds and sensitivity, but how that works i allready know;)
Is driving with the RC option also possible in autonomous mode?  And what is the diffrence exactly between Simplified Serial and RC mode for robotics? I thought i really needed Simplified Serial... (because everyone goes for that with sabertooth in the R2D2 world)   I am trying to understand that part;)
