Ohmnilabs Standalone icon Ohmnilabs Standalone — Connects Ohmnilabs Telepresence robot's UP Board COM to ARC, enabling drive and servo control (neck V0) and integration with ARC cameras. Try it →
Does ezrobot make a shield or hat for iotiny?
Does Ezrobot Make A Shield Or Hat For Iotiny?
Hello
I was wondering if there is a shield for the iotiny / ezb so you can soldier/screw in connections instead of plugging  them in?
With so many customers only makes sense.
Thank you
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
hi sproket
do you mean like a cover for the iotiny ?
#2   — Edited
The EZ-Robot IoTiny and v4 layout has 3 connections per I/O. This allows gnd, power and signal to each I/O pin. Where you are comparing it to lower cost controllers, such as Arduinos which have fewer pins per I/O. Usually only two gnds and one power.
By this design, having a "shield" is redundant because it is more effective to use 3 wire connectors to each pin. It is cheaper and cleaner for users to use connection cables like this...
www.amazon.ca/WMYCONGCONG-Splitter-Extension-Female-Connection/dp/B098K2KQM4/ref=sr_1_4_sspa?crid=RSLYBGP49LZV&keywords=servo+extension+cables&qid=1706671324&sprefix=servo+extension+cab%2Caps%2C358&sr=8-4-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
Yes I use connector cables.
I will look into 3, 8 pin connectors cables for more solid connection.
Saw some on adafruit.
Thank you
You're welcome! Using 3 or 8-pin connector cables can indeed provide a more solid and organized connection for your projects. Adafruit is a reputable source for such components, and they offer a variety of options that should meet your needs. If you have any more questions or need further assistance with your EZ-Robot IoTiny or any other Synthiam ARC-related queries, feel free to ask. Happy building!
#5   — Edited
Guess those are to wide.
Check if you can get the same "single plug" but three across and eight down. Then you have one large plug.
I prefer the individual connectors because I can swap in and out what I need.
