Floor Map icon Floor Map — Draws a live floor map of robot movement using Movement Panel, logging direction, distance and heading; configurable speed and turn settings. Try it →
#1   — Edited
Can you post a picture of your board - because there version #1 and Version #2 of the EZ-B were not sold to the public. The only versions sold to the public were...
2011: EZ-B v2.11 (wireless camera required USB dongle) 2012: EZ-B v3 (wireless camera required USB dongle) 2014: EZ-B v4.x/1 (camera connected to EZ-B via cable) 2015: EZ-B v4.2/2 [color=#111111][size=2][font=Verdana, Arial, Helvetica, sans-serif](camera connected to EZ-B via cable)[/font][/size][/color] 2016: EZ-B IoTiny [color=#111111][size=2][font=Verdana, Arial, Helvetica, sans-serif](camera connected to EZ-B via cable)[/font][/size][/color]
Hi DJ,
I wasn't really referring to v1 vs v2, but to v4 /1 and v4 /2. I don't have it right in front of me at the moment. Can you tell from an order number? 7-4694 I guess it would have been this one ordered on 7/10/2014 - I'm guessing that one is the 2014 model: [color=rgba(0, 0, 0, 0.847)][size=3][font="Times New Roman", serif]EZ[font="Times New Roman", serif][size=3][font="Times New Roman", serif][color=rgba(0, 0, 0, 0.847)][size=3][font="Times New Roman", serif]-[color=rgba(0, 0, 0, 0.847)][size=3][font="Times New Roman", serif]B[/font][color=rgba(0, 0, 0, 0.847)][size=3][font="Times New Roman", serif] v4[/font][/size][/color][/size][/color][/font][/size][/color][/font][/size][/font][/font][/size][size=3][font="Times New Roman", serif]
[size=3][font="Times New Roman", serif][font="Times New Roman", serif][size=3][font="Times New Roman", serif][size=3][size=3][font="Times New Roman", serif][color=rgba(0, 0, 0, 0.847058823529412)]In essence, is the same camera used between v4 versions and also IoTiny for years 2014, 2015 & 2016? Also, is there a [/color][color=#ba0084]possibility[/color][color=rgba(0, 0, 0, 0.847058823529412)] of using a higher definition camera (or is one available now) through the unit?[/color][/font][/size][/size][/font][/size][/font][/font][/size]
[size=3][font="Times New Roman", serif][font="Times New Roman", serif][size=3][font="Times New Roman", serif][size=3][size=3][font="Times New Roman", serif][color=rgba(0, 0, 0, 0.847058823529412)]Thank you.[/color][/font][/size][/size][/font][/size][/font][/font][/size]
[size=3][font="Times New Roman", serif][font="Times New Roman", serif][size=3][font="Times New Roman", serif][size=3][size=3][font="Times New Roman", serif][color=rgba(0, 0, 0, 0.847058823529412)]Jim[/color][/font][/size][/size][/font][/size][/font][/font][/size][/font][/size][/color]
All EZ-B v4 and IoTiny versions use the same camera
Excellent. Thank you. Any plans for an HD or night vision camera in the future?
I don't believe EZ-Robot has any plans for either of those. You can find USB versions from other manufacturers that will work with Synthiam's ARC Software.
As for higher resolution, ensure you have a processor fast enough to handle vision recognition algorithms for HD resolution. Read more on the camera device page here: https://synthiam.com/Software/Manual/Camera-Device-16120
