Relative Servos icon Relative Servos — Synchronize servos by designating a master; slave servos mirror scaled (decimal/negative) positions with min/max limits and pause control Try it →
The driver(s) are installed using the Windows exe file that is listed there .... Download the windows exe file... run it and it will install the drivers automatically....
rr
hopes it works
thanks
Just be aware, it could just be the same drivers you already have...
rr
then i removed and am done whit ez chronos.
dj
is this correct?
@nomad... don't go messing around with com port settings... There is no need to... Windows configures these ports automatically... If your watch doesn't work properly (as DJ mentioned) there could be a problem with the driver itself...
Maybe you need to wait for your Myo to arrive....
rr
sofar its working and norton says its good.but i know in a day orso. this week i expect all parts kd the myo end off this month. i never mess whit port setting,just wanted to know if these are ok. i power off the pc allreddy one time,sofar good.
thank you
#15
nomad, those settings look correct
