Neopixel Ring icon Neopixel Ring — ARC UI for onboard computers to control NeoPixel rings via serial: test/run patterns, preview and copy Arduino serial commands, includes sample code. Try it →
Russia
12AmP, 30A
Russia
12V, 30A
If you are refering to a hobbyist style Electronic Speed Controller (ESC), the answer is YES. Use the Modified servo Movement Panel.:)
*Note: you can press the EDIT button next to your post. That will allow you to edit rather than making new posts as corrections:)
