Sabertooth Movement Panel icon Sabertooth Movement Panel — Sabertooth movement panel: control two motors via Simplified Serial with variable speed sliders, movement buttons, and serial port options. Try it →
Ireland
Dual Axis Compass
Having problem connecting The Sure Electronics DC-SS503V100
ezb connects & then disconnects after a short while
no voltage drop on supply
connections 5v gnd scl sda
Any advice would be appreciated
There is some talk about it on THIS thread, check it out, might help.
Ireland
Thank you Gunner
2 x 10k resistors got the compass up & going
:P
Hello, what length wires did you use? I have been trying to get mine working for days now, I have put to 10k resistors in and my wire lengths are 20mm? it works fine for a 5 - 10 seconds and just shuts my ezb down? I then cycle the power and then works again for a sort time,Can anyone please help?
Ireland
@mae My initial problem was same as yours
wire length is approx 40mm one 10k between SCL & ground
one 10k between SDA & ground
Bravia, could you confirm you are putting the resisters between SCL & ground and SDA & ground? I thought it was between SCL & 5V ands SDA & 5v. I will swap them around and cross my fingers?
Ireland
YES To Ground that works for me
hello Bravia, many thanks for your help :) :) all up and running now thanks:D
Ireland
no problem great to hear you've had success
we depend on each other for support on this forum
Not using a Movement Panel for control of my robot ,so I have a lot of programming to do
