NMS Example icon NMS Example — Example NMS Level #1 navigation skill showing subscription to combined scan+location data, displaying position and scan info; source code included. Try it →
Dual H Bridge For $6.00
Just picked up this dual H Bridge for $6.00 on eBay(.99 for the H Bridge and the rest for shipping)
Here it is, I hope this will work for my 12v wheel motors.
L298N DRIVER MODULE H Bridge DC stepper Motor Driver Board module
Description: Driver chip: L298N Dual H Bridge DC Motor Driver IC
Drive part terminal power supply range Vs: +5 V ~ +35 V; If need to take power internal the board, the supply rangeVs: +7 V ~ +35 V
Drive part the peak current Io: 2A
The logical terminal power supply rangeVss: +5 V ~ +7 V ( take power inside the board +5 V)
The logic part working current range: 0 ~ 36mA
Control signal input voltage range:
Low level :-0.3V ? Vin ? 1.5V
High: 2.3V ? Vin ? Vss
Enable signal input voltage range:
Low: -0.3 ? Vin ? 1.5V (control signal is invalid)
High: 2.3V ? Vin ? Vss (control signal effective)
Maximum power consumption: 20W (when temperature T = 75 ?)
Storage temperature: -25 ? ~ +130 ?
Board Size: 55mm * 49mm * 33mm (with fixed copper pillar and the heat sink )
Driver Board Weight: 33g
Other Extensions: control direction indicators, the logic part take power interface.
