Ohmnilabs Standalone icon Ohmnilabs Standalone — Connects Ohmnilabs Telepresence robot's UP Board COM to ARC, enabling drive and servo control (neck V0) and integration with ARC cameras. Try it →
EZ-B + ArduiNIX Nixie Tube Driver
EZ-B + Arduinix Nixie Tube Driver
Updated on 10/6/2013 - Go to end of thread for more...
Introducing the ArduiNIX Nixie Tube Driver. I recently finishing putting this little piece of hardware together and am extremely impressed with everything from the PCB design to the online assembly instructions. There's even a tricked out R2 unit that helps with the soldering!
The ArduiNIX is a 4x20 multiplexed driver (4 Anodes/20 Cathodes) which essentially allows you to control up to 8 Nixie tubes or 80 neon bulbs (or some combination of the two). I haven't quite decided what I'm going to use it for yet but I was thinking that one of the openings on the front of the Omnibot shell would house a few Nixie tubes nicely...
Only thing I've done so far is connect it to the EZ-B and dial in the outputs at 170 volts. That's right kids, we're driving tubes here so we're dealing with potentially lethal voltages - notice the high voltage warnings on either side of the 4-pin Anode connector. So long as contact is momentary and you don't have a heart condition you should be fine, but you will get an adreniline rush for sure. I remember my grandfather telling me to only use one hand when working with LIVE tube cicuits. The last thing you want is for high voltage current to flow from one hand to the other, zapping your heart along the way. Well, zapping your brain isn't a very good idea either - trust me, that really hurts too...
I have yet to hook up any tubes but will update the post with more pics when I do...
#18
Ok, I see how the eyes open and close. Very cool.
But, what is making the blue rings around the eyes? That is a very nice effect. It looks like a circle of LEDS. Is that what they are? and where do you get them? and Exactly what size are they around?
ultracool!
#19
Just a quick eye test after replacing and rewiring the MiniM LED back-lights. An intermittent short in the old wiring harness ultimately got the first pair perished...
Running a short wake-up & sleep script coordinating the NL-7153 Nixie Tube eyes with the BlinkM MinM eye socket back-lighting...
Surgery and post-op pics:
Netherlands
Twitter YouTube
#20
Oh how I have missed your creepy videos:D
#21
Vanilla's now 3-layer brain has been successfully transplanted into his head! We still need to shorten and clean up his wiring a bit before making a video of the finished product...
For now, here are a few more surgery and post-op pics:
