Ultrasonic Distance icon Ultrasonic Distance — Displays HC-SR04 ultrasonic distance readings in ARC; scriptable via GetPing(), pausable, sets a variable with multiplier, optional NMS output Try it →
Netherlands
EZ-B WIFI Connect
EZ-B WIFI Connect
Hi There DJ sures,
I'd gave myself a present the Wifi module TLG10UA03.
Yesterday it came with the postal:)
I just configured it gave it my wifi ssid and password and a static ip. Tested it and connected it to the EZ-B.
Powered up the EZ-B and wanted to connect the ARC.
But ehm.... ehm... ohh.
How can I connect:)
#17
Model for.the ideal battery is UB645 6v lead acid battery 4.5 ah. It handles higher current than AA batteries and longer runtimes , search by model on eBay they are 10th dollars.
a battery has nothing to do with this issue jstarne1, I've contacted the manufactor hopefully they have a solution. Don't understand why it isn't responding to AT commands or why I received it in auto mode.
#19
Great news got the device configured now to get the virtual com port. Also it looks like my 2cell 910mAh battery won't supply enough current for the TLG to run off the EZ-B.
#20
@orwinc82!
That is great! I was taking a break from it....hopefully will start back up on it....I don't know what virtual com driver to use on the host PC......The one I am using opens one but no luck with EZB connection yet.......good luck on getting your power issue sorted. I am suprised as right now I am powering the EZB board and the TLG with only 5 AAA batteries...seems to work fine..do you have other things on?
v/r
Kevin
#21
@KKEAST
Nope but it seems a bit fishy I plug it to a power supply I created along time ago and connect it to the 12V rails and sum times the TLG turns on and sum times not. There shouldn't be a problem current wise with the power supply so maybe its my connections I have running to TX,RX,GND and 3.3V. Perhaps we can get Pabi!o to upload the drivers that were included with his for the virtual com port. I'll probably look into getting another 2 cell and paralleling it just for current incase future reasons.
#22
@orwnic82,
That does seem odd. I noticed that even if i have the RX and TX backward, the TLG won't even power up. Definitely don't want to get the Vcc and Ground mixed ....so I watch that very carefully of course.
That would be cool if Pabi!o could post the virtual driver he has....!
Kevin
#23
@kkeast
humm Mine turns on whenever I apply power to it from the usb regardless if the rx and tx are backwards however it wont if the rx and tx aren't connected. I almost applied the 5v to the TLG, forgot the V+ was 5V instead of 3.3V but I caught that before I powered up.
Hopefully He can upload them for us.
Netherlands
#24
Hi there i used the follow documents and software to configure my wifi-module.
I bought mine from ebay Ebay-link
On that page there is a section download there you can find al the info and software.
Hope it helps:)
