UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
Germany
Hi,
I would like to build a robot with a camera which should observe my house and my garden. It should use my existing wlan for connectivity, so I can control it remotely from each place in the world. Would it be possible to use the EZ-B with wifi instead of Bluetooth?
Thanks
That would be a neat robot! You are right, the range of bluetooth would be limiting for that application.
I would recommend XBee instead of WIFI. Adding an XBee interface to the EZ-B is very easy. We could arrange a custom price for you with an XBee module attached to the EZ-B, if you would like?
I don't know the cost of that yet, but let me know if you are interested and we'll put something together for you:)
DJ
Germany
Unfortunately XBee is not usual in Germany. So it would not solve my problem. And I have an already running wifi installation in my house...
Thank you for your offer. EZ-B is a great thing :) , but I have to look for an other solution. Thanks
dj can you make it easy to connect xbee pro to the ARC plz
tj
Hook up an Xbee to the ARC. and select the com port:) It should be the same method as using bluetooth
Czech Republic
DJ,
You proposed to arrange a custom price with an XBee module attached to the EZ-B, is it possible to do this incl receiver?
Thanks Petr
@donesvarc we attemtped in march to do that, but there was no demand so we decided to not offer custom one-off's. The XBee module can be purchased through Solarbotics, or many other places. It's really easy to connect - it merely needs power, gnd, rx and tx:) .. Simply connect to the communication header where the bluetooth module currently sits. Remove the bluetooth module and use the communication header - voila:D
Czech Republic
To DJ Sures:
Thanks a lot for your answer. I undestood very well, how easy is to change BT to XB, but main reason why I asked you was cost for shipping over A. ocean. Please is it possible to do for me to change BT by XB? Thank you once more
Petr
