ROS2 Connector icon ROS2 Connector — Bridge ARC to ROS2 via rosbridge: publish/subscribe topics for cameras, servos, ports, NMS, variables, scripts, and movement. Try it →
EZ-Bulider error loading plugin issue
EZ-Bulider Error Loading Plugin Issue
I just downloaded New version of ARC. Some plugin can not work! Anyone can help to repair this problems? Thanks a lot!
HAHA ! I except the challenge. Will see if ARC passes my test :-) Im using a Fusion5 Tablet with Win10. I sped it  up by getting rid of all the login and turned off Cortona. With the current build of ARC (the very last one) I can even open the program without needing a network connected first (thank you DJ for that fix). But it still takes several seconds more to load. Im still testing various parts of HEMI (my robot)  so not too critical for boot up speed as of yet. But will need it fast when HEMI goes into full use , I hope soon (the next gen of home healthcare robots...I hope:)
Hi All,
Is it the ARC not ready for "Advanced Speech Recognition"?
ARC works great with the advanced speech recognition. Check your key and settings as the message reads
Hi DJ,
I have tried to switch different regions and use the default API Key. Any mistakes I did?
You can only use the region registered in your azure account. Your cognitive services will present a region based on when you created the account.
#15   — Edited
Oh! I see! Thanks a lot!
