Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
EZ-Robot JD Shoulder Servo Not Rotating
Thanks, I have the Bing Speech Rec skill working. Now, I am noticing that JD's right shoulder isn't rotating anymore, so Stand from Sit doesn't work correctly, any movement that rotates the right shoulder. It can't be a wiring issue as that is internally wired, if I am not mistaken. Can you provide any troubleshooting on that new issue?
Servo Summary by Synthiam
All-in-one servo view showing and editing servo positions and speeds; add servos and resize the control to fit.
Hi joesox,
Nomad_6R has shared some hardware troubleshooting tips that can be useful if your servo appears to be burnt or unresponsive. Here's a quick summary of the advice and a few additional tips:
  • Smell Check: If you notice a burnt odor, it might indicate that the servo has failed.
  • Cable Connection: Double-check that all cables are correctly connected.
  • Open the Chest: As mentioned, there are four screws on the back side that secure the cover (or "chest"). Removing these may allow you to inspect the internal wiring and connections.
  • Testing Ports: Swap the servo by connecting it to another EZ-B servo port that you know works properly. This will help confirm if the issue is with the servo or the original port.
For further details on identifying and troubleshooting humanoid shoulder servos, you can check out this link from EZ-Robot:
Identifying Humanoid Shoulder Servos
Please note, while these steps can help diagnose hardware issues, Synthiam provides support for ARC software and robot skills rather than direct hardware modifications. If you encounter any issues related to configuring or troubleshooting servos within ARC, feel free to ask!
Do you need any assistance with ARC software settings or further guidance on configuring your robot skills? Let me know-I'm here to help!
