Custom Movement Panel icon Custom Movement Panel — Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors Try it →
EZB control from Android tablet
EZB Control From Android Tablet
I had hoped to control my robotic device with an android tablet.  I tried to download the ARC mobile version on my android 12 tablet through GooglePlay but was greeted with an error message that my tablet was not supported since the app was designed for an earlier android version.  Am I out of luck . . or maybe doing something wrong?  Thanks.
Craig
seigezapf
what happens when you download straight from here on synthiam ?
Thanks for the response Nomad 6R.  The Synthium ARC download screen only lists the three (PC?) downloads for ARC.  There is no download selection for ARC Mobile.  I tried to download TEAMS on my android - ARC Installer (Teams).exe.msi - the resulting message is "Can't Open file."  So the Teams installer doesn't work on my android as far as I can tell.  I am a new android user, so maybe I am doing something wrong?  The Teams download is what I have on my PC.
Craig
if you have the mobile in your project , you have to look for , synthiam .
 you have to look under synthiam . then you see synthiam ARC .
Thank you for your response Nomad 6R.  Unfortunately I did not understand your suggestions.  Do I have mobile in my project?  Do you mean a user interface?  I believe that is for PC control.  Look for synthium?  Look under synthium?  Do you mean the Synthium website?  I did find ARC in the Synthium website, but as I mentioned, there is no ARC Mobile download - only downloads for PC.  I apologize if I am misunderstanding your suggestions.
Craig
yes its the mobile interface in your project pc . then download synthiam ( ARC )  look for my projects . you will see  your mobile interface .
#6   — Edited
Thank you again Nomad 6R for your suggestions.  I have read the ARC UI information and viewed the tutorial.  I also downloaded and installed ARC UI on my PC.  When I follow the tutorial instructions I am OK up to the point where I am instructed to select Properties under the Project heading.  Unlike the tutorial, the ARC UI selection does not appear in the Properties screen on my panel.  So I cannot fill in the required information (e.g. password).  Without that step I can't proceed further.  I must be doing something wrong, but have no idea what.  For what it is worth, I was able to build a user interface - but it was a separate "add" selection from ARC UI.
Craig
i believe the pasword is same as here and your project .
The ARC UI tutorial shows a screen in which things like the ARC UI password are entered.  That screen is accessed through Properties.  When I select Properties the panel that opens does not have "ARC UI" as a choice, thus I cannot fill out the necessary information.
When you say the password is the same as "here."  I'm not sure where "here" is.
Maybe my project is not eligible for some reason.
Thanks for your responses.
Craig
