EZB-V4 Battery / A/C Adapter Usage
Hello everyone,
Have a power question and any advice with this is appreciated. I’ve searched the forums but haven’t quite found a thread that answers my questions.
I’m building a service bot that stands 5’8" running 2 servos for the Head, 5-6 for each arm and gripper, 2 -4 Led’s For eyes, an el-wire ring in the chest around the speaker, and two 12v (max) motors for the base wheels running through a motor controller connected to the ezb.
I’ve been using the battery pack provided with the developer kit with rechargeable AA’s in the provided battery pack but it’s already insufficient and I haven’t even added the arms yet. Dies within 20 minutes at best. I’ve seen LiPo recommendations but this is what I’m looking for:
what batteries are are you running?  How much are you operating off of them (device wise) and how much longevity do you get? are there any ac adapters on the market that you’ve been able to use for larger projects that can allow you to bypass batteries all together during prototyping? Anyone have experience using automotive SLA’s regulated down to work with the EZB? Overall I’m looking for the best way to keep my bot powered for the longest amount of time weather it involve a teathered electrical connection or rechargeable and wireless. It’s a front I’m fuzzy on and could use advice with so I don’t accidentally burn out hundreds of dollars in equipment and components.
EZ-B Settings by EZ-Robot
Configures and pushes WiFi SSID, password, system name and channel to EZ-Robot EZ-B v4 from ARC; saves settings with project for quick redeploy.
EZ-B V4 Info by Synthiam
Displays EZ-B v4 internal temperature and battery voltage, shows built-in battery monitor and LiPo protection settings in Connection Control.
Hey kull, for bench power supplies, the easiest solution is to find a higher amperage digital switching supply. Although, I tend to prefer adjustable bench supplies because you can monitor the amperage draw.
The answer to your question regarding how long batteries last is related to the current draw - so it’s impossible for me to answer but you can identify it yourself. If you are serious about your project, a bench adjustable power supply on eBay is a good choice and only costs approximately $100 usd. That will give you the current draw which will help calculate your power consumption.
Because the motors will be holding weight that is specific to your configuration, it’s not as simple as assuming a servo draws X amps. You will have accurate assumptions by monitoring the current while the robot is in use.
Because of the hardware you’ve described, I would configure the adjustable bench supply for 7.4 volts
If your robot is drawing 1 amp continuously, and you want it to run for 4 hours, you’d need a 4 amp battery. The batteries you will find have an amp hour rating. That’s how many amps of current it provides in an hour.
Man! I'd be afraid to plug that one in. How can they sell this for that cheap?? I may just have to get one and try it out. Carefully and under a close watch. LOL.
#4   — Edited
OK, I pulled the trigger and bought one. Price for mw with shipping was just under 9 USD. We'll see but how can I go wrong with a digital display and the ability to adjust from 0 - 30 volts and it will stand up to 10 amps. Heck, if I accidentally send more than 10 amps through it and fry it, the smoke show will be worth at least the $9 I spent. LOL.
However I'll have to wait up to 28 days for it to arrive. I guess this what they mean when they say "Slow Boat From China". LOL
Thanks for the heads up DJ!
Lol that’s amazing. I thought of getting one to just to see. Jeremie and I have similar ones that cost 10 times more and work great. The hardest part is finding 10 amp versions like that.
I just purchased one, the cost of 3..99 shipping was almost the cost of the bench power supply,  we will see in a couple of months.
#7   — Edited
Haha see - maybe these guys are actually making a bit of money because so many people are buying it at this price. It wouldn't cost much less than the asking price to manufacturer the product in high quantity... specifically since the product has been on the market for a number of years and the cost of r&d has been covered long ago
.... or, they light on fire and burst into flames when we turn it on
Yeah.  I think I'll wait and make sure you all survive before buying one;)  Alan
