Getrss icon Getrss — Fetch RSS via GetRSS command; populates $RSSSuccess, $RSSErrorMsg and arrays $RSSTitles, $RSSDescriptions, $RSSLinks, $RSSDates for scripts. Try it →
Resolved Resolved by amin!
Ezbpi Server Camera Error
I realized that I am not able to flip the Raspberry Pi's camera, I get the following error message?
Error Camera.SetCaptureImage: AForge.Imaging.UnsupportedImageFormatException: Source pixel format is not supported by the filter. bei AForge.Imaging.Filters.BaseTransformationFilter.CheckSourceFormat(PixelFormat pixelFormat) bei AForge.Imaging.Filters.BaseTransformationFilter.Apply(BitmapData imageData) bei AForge.Imaging.Filters.BaseTransformationFilter.Apply(Bitmap image) bei EZ_B.Camera.x5wORRJh49(Object )
Raspberry Pi by Pi Foundation
Synthiam ARCx runs natively on Raspberry Pi 4/5, controlling robots via browser with EZB controllers, vision, speech and scripting.
Servos ✕
ADC ✕
Digital ✕
Camera Device by Synthiam
Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts
Also I am getting timeout errors... Camera Initialized: EZB://192.168.178.60:24 @ 640x480
EZ-B v4 Camera Error: System.TimeoutException: Timeout für den Vorgang wurde überschritten. bei EZ_B.EZBv4Video.DwiGDUj2lU(Int32 , Object ) Camera Disabled
Twitter
Can you please share the log for EZBPi from your Raspberry Pi console? Do you see any errors? Which Raspberry Pi are you using?
Most of the times I will just have to connect a few times and eventually it will work out and stay stable... I am running a Pi Zero W
But here is on example error the EZBPi logged...
Raspberry EZBPi Version: 2019.3.29.0 Verbose logging is: False Serial port is: /dev/serial0 EZB: TCP Started on port 23 EZ-B Server started on TCP Port: 23 Camera: TCP Started on port 24 Camera Server started on TCP Port: 24 Press ESC to quit Camera: TCP Connection from: 192.168.178.61 Camera disconnected on tty:0 Camera: TCP Connection from: 192.168.178.61 *** Error in `mono': free(): invalid pointer: 0xb3e59f68 *** Stacktrace:
at <0xffffffff> at (wrapper managed-to-native) MMALSharp.Native.MMALUtil.mmal_port_pool_destro y (MMALSharp.Native.MMAL_PORT_T*,MMALSharp.Native.MMAL_POOL_T*) <0x0003b> at MMALSharp.Ports.PortBase.DestroyPortPool () <0x00043> at MMALSharp.MMALComponentBase.CleanPortPools () <0x001c7> at MMALSharp.MMALConnectionImpl.Destroy () <0x0002b> at MMALSharp.MMALConnectionImpl.Dispose () <0x00043> at MMALSharp.Components.MMALDownstreamComponent.ClosePipelineConnections () <0 x00133> at MMALSharp.Components.MMALDownstreamComponent.Dispose () <0x00043> at EZBPi.EZBProgram._CAMServer_OnConnection (System.Net.Sockets.TcpClient,Syst em.Net.Sockets.NetworkStream,int) <0x0071f> at EZBPi.TCPServer.handleClientScriptCommand (object) <0x000c7> at System.Threading.ThreadHelper.ThreadStart_Context (object) <0x0010f> at System.Threading.ExecutionContext.RunInternal (System.Threading.ExecutionCo ntext,System.Threading.ContextCallback,object,bool) <0x001bf> at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext,Sy stem.Threading.ContextCallback,object,bool) <0x0002b> at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext,Sy stem.Threading.ContextCallback,object) <0x0005b> at System.Threading.ThreadHelper.ThreadStart (object) <0x00047> at (wrapper runtime-invoke) .runtime_invoke_void__this___object (objec t,intptr,intptr,intptr) <0x000df>
Native stacktrace:
Debug info from gdb:
[New LWP 1095] [New LWP 1096] [New LWP 1097] [New LWP 1098] [New LWP 1099] [New LWP 1101] [New LWP 1102] [New LWP 1103] [New LWP 1104] [New LWP 1105] [New LWP 1106] [New LWP 1107] [New LWP 1108] [New LWP 1109] [New LWP 1114] [New LWP 1115] [New LWP 1116] [New LWP 1119] [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1". 0xb6eaf3c0 in read () at ../sysdeps/unix/syscall-template.S:84 84 ../sysdeps/unix/syscall-template.S: Datei oder Verzeichnis nicht gefunde n. Id Target Id Frame
  • 1 Thread 0xb6fd6000 (LWP 1094) "Main" 0xb6eaf3c0 in read () at ../sysdeps/u nix/syscall-template.S:84 2 Thread 0xb63ff470 (LWP 1095) "SGen worker" 0xb6eab94c in __pthread_cond_w ait (cond=0x3258f0, mutex=0x3258bc) at pthread_cond_wait.c:186 3 Thread 0xb6adb470 (LWP 1096) "Finalizer" 0xb6eae014 in futex_abstimed_wai t_cancelable (private=0, abstime=0x0, expected=1, futex_word=0x31d8c0) at ../sys deps/unix/sysv/linux/futex-internal.h:205 4 Thread 0xb40ad470 (LWP 1097) "TCP Server for " 0xb6eaf6a0 in accept () at ../sysdeps/unix/syscall-template.S:84 5 Thread 0xb3dff470 (LWP 1098) "TCP Server for " 0xb6eaf6a0 in accept () at ../sysdeps/unix/syscall-template.S:84 6 Thread 0xb3cff470 (LWP 1099) "Timer-Scheduler" 0xb6eabce8 in __pthread_co nd_timedwait (cond=0xc11930, mutex=0xc11914, abstime=0xb3cfe35c) at pthread_cond _timedwait.c:198 7 Thread 0xb3fad470 (LWP 1101) "Timer-Scheduler" 0xb6eabce8 in __pthread_co nd_timedwait (cond=0x3260c0, mutex=0x3260a8, abstime=0xb3facd54) at pthread_cond _timedwait.c:198 8 Thread 0xb3aff470 (LWP 1102) "Threadpool work" 0xb6eabce8 in _pthread_co nd_timedwait (cond=0xb3e032f0, mutex=0xb3e03320, abstime=0xb3afed60) at pthread cond_timedwait.c:198 9 Thread 0xb38bc470 (LWP 1103) "VCHIQ completio" 0xb6e2980c in ioctl () at ../sysdeps/unix/syscall-template.S:84 10 Thread 0xb30bc470 (LWP 1104) "HDispmanx Notif" 0xb6eae014 in futex_abstim ed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0xb39da6e8 ) at ../sysdeps/unix/sysv/linux/futex-internal .h:205 11 Thread 0xb28bc470 (LWP 1105) "HTV Notify" 0xb6eae014 in futex_abstimed_wa it_cancelable (private=0, abstime=0x0, expected=1, futex_word=0xb39d9864 ) at ../sysdeps/unix/sysv/linux/futex-internal.h:2 05 12 Thread 0xb20bc470 (LWP 1106) "HCEC Notify" 0xb6eae014 in futex_abstimed_w ait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0xb39da5ec ) at ../sysdeps/unix/sysv/linux/futex-internal.h :205 13 Thread 0xb188f470 (LWP 1107) "Threadpool work" 0xb6eabce8 in _pthread_co nd_timedwait (cond=0xb3e032f0, mutex=0xb3e03320, abstime=0xb188ed60) at pthread cond_timedwait.c:198 14 Thread 0xb11ff470 (LWP 1108) "vc.ril.camera" 0xb6eae014 in futex_abstimed _wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0xb14d41d8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205 15 Thread 0xb09ff470 (LWP 1109) "vc.camera_info" 0xb6eae014 in futex_abstime d_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0xb14e70c8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205 16 Thread 0xb3bff470 (LWP 1114) "TCP Server for " 0xb6eb04cc in __waitpid (p id=1120, stat_loc=0xb3bfd900, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c :29 17 Thread 0xaf2ff470 (LWP 1115) "vc.ril.video_sp" 0xb6eae014 in futex_abstim ed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0xeb80d8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205 18 Thread 0xaeaff470 (LWP 1116) "vc.ril.image_en" 0xb6eae014 in futex_abstim ed_wait_cancelable (private=0, abstime=0x0, expected=1, futex_word=0xe4b4e8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205 19 Thread 0xad8ff470 (LWP 1119) "Threadpool work" 0xb6eabce8 in _pthread_co nd_timedwait (cond=0xb3e032f0, mutex=0xb3e03320, abstime=0xad8fed60) at pthread cond_timedwait.c:198
Thread 19 (Thread 0xad8ff470 (LWP 1119)): #0 0xb6eabce8 in __pthread_cond_timedwait (cond=0xb3e032f0, mutex=0xb3e03320, a bstime=0xad8fed60) at pthread_cond_timedwait.c:198 #1 0x001918c0 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 18 (Thread 0xaeaff470 (LWP 1116)): #0 0xb6eae014 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expect ed=1, futex_word=0xe4b4e8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205 #1 do_futex_wait (sem=sem@entry=0xe4b4e8, abstime=0x0) at sem_waitcommon.c:115 #2 0xb6eae158 in _new_sem_wait_slow (sem=0xe4b4e8, abstime=0x0) at sem_waitcom mon.c:282 #3 0xb13679bc in mmal_component_action_thread_func () from /opt/vc/lib/libmmal core.so #4 0xb3987cc4 in vcos_thread_entry (arg=0xe4b400) at /home/dc4/projects/staging /userland/interface/vcos/pthreads/vcos_pthreads.c:144 #5 0xb6ea4fc4 in start_thread (arg=0xaeaff470) at pthread_create.c:335 #6 0xb6e30bc8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/a rm-linux-gnueabihf/libc.so.6 Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 17 (Thread 0xaf2ff470 (LWP 1115)): #0 0xb6eae014 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expect ed=1, futex_word=0xeb80d8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205 #1 do_futex_wait (sem=sem@entry=0xeb80d8, abstime=0x0) at sem_waitcommon.c:115 #2 0xb6eae158 in _new_sem_wait_slow (sem=0xeb80d8, abstime=0x0) at sem_waitcom mon.c:282 #3 0xb136795c in mmal_component_action_thread_func () from /opt/vc/lib/libmmal core.so #4 0xb3987cc4 in vcos_thread_entry (arg=0xeb7ff0) at /home/dc4/projects/staging /userland/interface/vcos/pthreads/vcos_pthreads.c:144 #5 0xb6ea4fc4 in start_thread (arg=0xaf2ff470) at pthread_create.c:335 #6 0xb6e30bc8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/a rm-linux-gnueabihf/libc.so.6 Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 16 (Thread 0xb3bff470 (LWP 1114)): #0 0xb6eb04cc in __waitpid (pid=1120, stat_loc=0xb3bfd900, options=0) at ../sys deps/unix/sysv/linux/waitpid.c:29 #1 0x000bbb44 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 15 (Thread 0xb09ff470 (LWP 1109)): #0 0xb6eae014 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expect ed=1, futex_word=0xb14e70c8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205 #1 do_futex_wait (sem=sem@entry=0xb14e70c8, abstime=0x0) at sem_waitcommon.c:11 5 #2 0xb6eae158 in _new_sem_wait_slow (sem=0xb14e70c8, abstime=0x0) at sem_waitc ommon.c:282 #3 0xb136795c in mmal_component_action_thread_func () from /opt/vc/lib/libmmal core.so #4 0xb3987cc4 in vcos_thread_entry (arg=0xb14e6fe0) at /home/dc4/projects/stagi ng/userland/interface/vcos/pthreads/vcos_pthreads.c:144 #5 0xb6ea4fc4 in start_thread (arg=0xb09ff470) at pthread_create.c:335 #6 0xb6e30bc8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/a rm-linux-gnueabihf/libc.so.6 Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 14 (Thread 0xb11ff470 (LWP 1108)): #0 0xb6eae014 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expect ed=1, futex_word=0xb14d41d8) at ../sysdeps/unix/sysv/linux/futex-internal.h:205 #1 do_futex_wait (sem=sem@entry=0xb14d41d8, abstime=0x0) at sem_waitcommon.c:11 5 #2 0xb6eae158 in _new_sem_wait_slow (sem=0xb14d41d8, abstime=0x0) at sem_waitc ommon.c:282 #3 0xb136795c in mmal_component_action_thread_func () from /opt/vc/lib/libmmal core.so #4 0xb3987cc4 in vcos_thread_entry (arg=0xb14d40f0) at /home/dc4/projects/stagi ng/userland/interface/vcos/pthreads/vcos_pthreads.c:144 #5 0xb6ea4fc4 in start_thread (arg=0xb11ff470) at pthread_create.c:335 #6 0xb6e30bc8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/a rm-linux-gnueabihf/libc.so.6 Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 13 (Thread 0xb188f470 (LWP 1107)): #0 0xb6eabce8 in __pthread_cond_timedwait (cond=0xb3e032f0, mutex=0xb3e03320, a bstime=0xb188ed60) at pthread_cond_timedwait.c:198 #1 0x001918c0 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 12 (Thread 0xb20bc470 (LWP 1106)): #0 0xb6eae014 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expect ed=1, futex_word=0xb39da5ec ) at ../sysdep s/unix/sysv/linux/futex-internal.h:205 #1 do_futex_wait (sem=sem@entry=0xb39da5ec , abstime=0x0) at sem_waitcommon.c:115 #2 0xb6eae158 in __new_sem_wait_slow (sem=0xb39da5ec , abstime=0x0) at sem_waitcommon.c:282 #3 0xb39c0c44 in cecservice_notify_func () from /opt/vc/lib/libbcm_host.so #4 0xb3987cc4 in vcos_thread_entry (arg=0xb39da600 ) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144 #5 0xb6ea4fc4 in start_thread (arg=0xb20bc470) at pthread_create.c:335 #6 0xb6e30bc8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/a rm-linux-gnueabihf/libc.so.6 Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 11 (Thread 0xb28bc470 (LWP 1105)): #0 0xb6eae014 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expect ed=1, futex_word=0xb39d9864 ) at ../sysdeps /unix/sysv/linux/futex-internal.h:205 #1 do_futex_wait (sem=sem@entry=0xb39d9864 , abstime=0x0) at sem_waitcommon.c:115 #2 0xb6eae158 in __new_sem_wait_slow (sem=0xb39d9864 , abstime=0x0) at sem_waitcommon.c:282 #3 0xb39c0084 in tvservice_notify_func () from /opt/vc/lib/libbcm_host.so #4 0xb3987cc4 in vcos_thread_entry (arg=0xb39d9878 ) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144 #5 0xb6ea4fc4 in start_thread (arg=0xb28bc470) at pthread_create.c:335 #6 0xb6e30bc8 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/a rm-linux-gnueabihf/libc.so.6 Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 10 (Thread 0xb30bc470 (LWP 1104)): #0 0xb6eae014 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expect ed=1, futex_word=0xb39da6e8 ) at ../sysdeps/ unix/sysv/linux/futex-internal.h:205 #1 do_futex_wait (sem=sem@entry=0xb39da6e8 , abstime=0x0) at sem_waitcommon.c:115 #2 0xb6eae158 in __new_sem_wait_slow (sem=0xb39da6e8 , abstime=0x0) at sem_waitcommon.c:282 #3 0xb39c4150 in dispmanx_notify_func () from /opt/vc/lib/libbcm_host.so #4 0xb3987cc4 in vcos_thread_entry (arg=0xb39db428 ) at / home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144 #5 0xb6ea4fc4 in start_thread (arg=0xb30bc470) at pthread_create.c:335 Backtrace stopped: Cannot access memory at address 0x0
Thread 9 (Thread 0xb38bc470 (LWP 1103)): #0 0xb6e2980c in ioctl () at ../sysdeps/unix/syscall-template.S:84 #1 0xb39a1010 in completion_thread () from /opt/vc/lib/libvchiq_arm.so #2 0xb3987cc4 in vcos_thread_entry (arg=0xb39b4318 ) at /hom e/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144 #3 0xb6ea4fc4 in start_thread (arg=0xb38bc470) at pthread_create.c:335 Backtrace stopped: Cannot access memory at address 0x8d720f8
Thread 8 (Thread 0xb3aff470 (LWP 1102)): #0 0xb6eabce8 in __pthread_cond_timedwait (cond=0xb3e032f0, mutex=0xb3e03320, a bstime=0xb3afed60) at pthread_cond_timedwait.c:198 #1 0x001918c0 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 7 (Thread 0xb3fad470 (LWP 1101)): #0 0xb6eabce8 in __pthread_cond_timedwait (cond=0x3260c0, mutex=0x3260a8, absti me=0xb3facd54) at pthread_cond_timedwait.c:198 #1 0x002488f4 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 6 (Thread 0xb3cff470 (LWP 1099)): #0 0xb6eabce8 in __pthread_cond_timedwait (cond=0xc11930, mutex=0xc11914, absti me=0xb3cfe35c) at pthread_cond_timedwait.c:198 #1 0x0021caf8 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 5 (Thread 0xb3dff470 (LWP 1098)): #0 0xb6eaf6a0 in accept () at ../sysdeps/unix/syscall-template.S:84 #1 0x0022e1c0 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 4 (Thread 0xb40ad470 (LWP 1097)): #0 0xb6eaf6a0 in accept () at ../sysdeps/unix/syscall-template.S:84 #1 0x0022e1c0 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 3 (Thread 0xb6adb470 (LWP 1096)): #0 0xb6eae014 in futex_abstimed_wait_cancelable (private=0, abstime=0x0, expect ed=1, futex_word=0x31d8c0) at ../sysdeps/unix/sysv/linux/futex-internal.h:205 #1 do_futex_wait (sem=sem@entry=0x31d8c0, abstime=0x0) at sem_waitcommon.c:115 #2 0xb6eae158 in __new_sem_wait_slow (sem=0x31d8c0, abstime=0x0) at sem_waitcom mon.c:282 #3 0x001ac174 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 2 (Thread 0xb63ff470 (LWP 1095)): #0 0xb6eab94c in __pthread_cond_wait (cond=0x3258f0, mutex=0x3258bc) at pthread _cond_wait.c:186 #1 0x002158e8 in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 1 (Thread 0xb6fd6000 (LWP 1094)): #0 0xb6eaf3c0 in read () at ../sysdeps/unix/syscall-template.S:84 #1 0x0021f17c in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?)
================================================================= Got a SIGABRT while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application.
Abgebrochen
#4   — Edited
Normally it gives me a few disconnects and logs something like this...
Raspberry EZBPi Version: 2019.3.29.0 Verbose logging is: False Serial port is: /dev/serial0 EZB: TCP Started on port 23 EZ-B Server started on TCP Port: 23 Camera: TCP Started on port 24 Camera Server started on TCP Port: 24 Press ESC to quit Camera: TCP Connection from: 192.168.178.61 Camera: TCP Connection from: 192.168.178.61 mmal: mmal_port_enable: vc.ril.camera:ctr:0(0xb14cb4a0) already enabled Camera disconnected on tty:1 Camera disconnected on tty:0 Camera: TCP Connection from: 192.168.178.61
Once I am connected the camera seems to stay stable!
Sweet, thanks a lot...I will try later today!!:D
Same thing...here is the error log...it quite long so I will put it to a new comment!
