France
EZBPi server - access to the Pi GPIOs
Ezbpi Server - Access To The Pi Gpios
Hi,
I have successfully connected ARC to the Pi using the EZBPi server, but I don't understand how to access the GPIOs of the Pi. If I want to set or read a digital port, how do I know which port in ARC correspond the right GPIO pinout?
Raspberry Pi by Pi Foundation
Synthiam ARCx runs natively on Raspberry Pi 4/5, controlling robots via browser with EZB controllers, vision, speech and scripting.
Servos ✕
ADC ✕
Digital ✕
Read Digital by Synthiam
Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval.
Set Digital by Synthiam
Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only.
Thanks PTP,
I was aware of the Pi GPIOs map, but I didn't get that there was a direct match between ARC port numbers and the Pi GPIO numbers. I am going to test it tonight.
Bear in mind the raspberry pi is not 5v tolerant.
if you are reading logic voltages the limit is 3.3v
Ok, I made a test and it doesn't work. As a test, I try to switch on/off a LED with the "Set Digital" control. It works with my EZB v4 (so no issue with the LED), but not with the Pi (I have tested different pinouts)...
Can you explain how you wire the led ?
you can’t wire a led without a resistor.
The LED is indeed wired with a resistor and works with the EZB v4 (I can switch it with the Set Digital control). It works also on the Pi if I plug it on the 3.3v pinout (+ground). It just seems that i cannot set digital on other GPIOs...
#7   — Edited
Let's troubleshoot the issue:
connect your led (and the resistor) to pin 12 (GPIO 18)
open a console and run the commands below:
initialize the pin direction:
echo "out" > /sys/class/gpio/gpio18/direction
switch on:
echo "1" > /sys/class/gpio/gpio18/value
switch off:
echo "0" > /sys/class/gpio/gpio18/value
Let me know if you can toggle the led.
OK, thanks ptp
But first command, first error.
bash: /sys/class/gpio/gpio18/direction: No such file or directory
I don't have a /gpio18 folder in  /sys/class/gpio
