Robot Skill To Camera icon Robot Skill To Camera — Capture a robot skill's display and stream selected area as video to a configured camera device with FPS and live preview crop. Try it →
EZBv4 Disconnects on RGB Enable
Ezbv4 Disconnects On RGB Enable
My EZBv4 disconnects immediately when I connect or enable the RGB LED. I already tried flipping the cable 180 but that didn't help.
I'm running ARC and I noticed the EZB temperature shown in ARC is higher when the RGB is connected. In the EZB status it shows 30 and 21 (not sure why there are two values) when the RGB is connected, and about 29 when the RGB is disconnected.
Any ideas?
EZB Connection by Synthiam
Debug by Synthiam
Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear.
@athena
yes i would love this test " If you’d like, I can also tell you how to check the EZ-B v4 status " .
Absolutely - here’s a simple EZ-B v4 health check you can do in ARC to help confirm whether the I2C side of the board is the problem.
1) Check the EZ-B v4 status in ARC
  1. Connect to the EZ-B Connection skill.
  2. Look at the status area for the board.
  3. Note these values:
    • CPU temperature
    • input voltage / battery voltage
    • whether ARC reports the connection as stable or drops
If you can, send a screenshot of the status area with the RGB connected and with it disconnected.
2) Use the Debug skill to watch the connection
Add the Debug robot skill:
  • Project Add Robot Skill General Debug
Then:
  1. Clear the log
  2. Connect the EZ-B v4
  3. Enable the RGB skill
  4. Watch the log right when it disconnects
The Debug skill can help show if ARC is losing communication because of the device response or a connection fault.
3) Do a minimal hardware test
For this test, disconnect everything except:
  • EZ-B v4 power
  • ARC connection
  • the RGB device
Then try enabling the RGB again.
Results:
  • If it disconnects immediately: likely the EZ-B v4 I2C hardware or the cable/device connection
  • If it stays connected: another peripheral or power load may be contributing
4) Compare with another I2C device if you have one
If you have any other I2C sensor/module, plug it into the same EZ-B v4 and test it.
  • If every I2C device causes disconnects: the v4’s I2C side is likely damaged
  • If only the RGB device causes disconnects: the RGB cable/device or address may still be the issue
5) What the status numbers mean
You mentioned seeing "30 and 21" in the status.
That is usually showing two different board readings, commonly:
  • CPU temperature
  • battery/input voltage
A slight change there is normal and would not usually explain an instant disconnect.
6) What I’d like you to test next
Please try this exact sequence:
  1. Power the EZ-B v4 with only one EZ-B board connected
  2. Open ARC and connect
  3. Open Debug
  4. Plug in the RGB device
  5. Enable the RGB skill
  6. Tell me:
    • does it disconnect instantly?
    • does ARC freeze?
    • does the RGB light turn on briefly?
    • what do the status values show right before disconnect?
Helpful ARC docs
If you want, I can give you a very short step-by-step I2C isolation test next that takes less than 5 minutes and will tell us whether the issue is the EZ-B v4, the cable, or the RGB device.
@athena
arc doesn't freeze . i test with a 8x8 and same result . when power on ezbv the rgb lights up original , 4 blue dots and 1 white in the middle . no sound , it takes a second and then it disconnect from ARC .
If you want, I can give you a very short step-by-step I2C isolation test , please give me this test .
Sorry, I can't continue helping in this thread. It's grown long enough that my context window will require too much extra processing, which makes follow-ups unreliable and I can start making mistakes.
A couple of options:
  • Start a new thread that picks up where we left off - fresh context, faster responses.
  • Or get unlimited interaction with me through ARC's built-in AI Assistant agent: Synthiam AI Assistant
