Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
I'm a newbie to the forum and just in the planning stage ( and gathering parts) for the OmniBot conversion. D.J. calls for a QR111D edge detectors. I can"t seem to find one online. Anyone know if there is an equivilent part (w/part number) available? Will any of the detectors from solorbotics work? Thanks in advance.
Bringing this back onto the edge detector topic. Am I right in assuming mounting one of these on the front, facing down would be used to make sure I don't drive down the stairs by accident? (basically, have a script that stops moving forward or stops and turns when the sensor CAN'T see anything)?
My family room is one step down from the kitchen. If my wife will let me, I will put a ramp on one side of the opening for the bot, but I need to make sure he only uses the ramp and doesn't fall down the step (unless I design some kind of self-righting mechanism, but that will probably come late in the build if at all).
hey @thetechguru
Yep thats the basic idea i believe. Below is something DJ wrote in another topic.
"On my Wall-E, I used a sharp IR distance sensor (the same type you are using) pointing down on an angle.
During initialization, i get the value of the IR sensor. If the value changes within a determined percentage, I backup and turn around. This helps for both raised and lowered surfaces."
Thanks both. Thegoodrobot, you just exemplified the ddifference between an engineer and a technician. I was looking to engineer an elegent solution, and you provided a simple practical one that will work perfectly well.
@thetechguru he mounted a sr04 facing down right? So this confirms it works?
@jstarne1,
I don't see any reason why this would not work. You just need to ensure you have the sensor overhanging enough which may/may-not work. Are you using your RAD track base or the Omnibot wheel base? I am looking at my RAD 2.0 base and you could easily mount one in front of the cup sensor facing the floor and any drop would likley be seen before your bot went over the edge. Problem will be seen when you approach the drop off from an angle...unless you have multiple sensors (an option...one on each corner). Tracks will generally an advantage over wheels as you can 'go over the edge' with the tracks a bit and still pull back.
vr
Kevin
#15
@kkeast I planned on mounting it under the base , currently using Omnibot base to get things going , I was going to mount underneath but with about a 30-45 degree angle forward so that it should detect a cliff about 6 inches before the front wheels. I have the one.sr04 that came with.the kit and bought 3 more on ebay which should be here anytime this week. So I will have a total of 4. So I could have one radar , a front cliff sensor , a back up/ cliff sensor , and maybe I would use.the last one for to avoid tables. Always any suggestions.of what to.do with.my 4 sensors is greatly appreciates:)
#16
soooo.......what sensors are we going with for edge detection?
