Roll Pitch Yaw icon Roll Pitch Yaw — Rotate and position camera or object with roll/pitch/yaw controls; save camera settings; bind or monitor a 3-value EZ-Script array for live rotation. Try it →
Elseif Is Broken
Elseif Is Broken
@DJ,
The ElseIf is broken:
The code below never stops !
$buffer="[123 456 789]"
$len=Length($buffer)
$ix=0
$start=-1
$end=-1
repeatwhile($ix<$len)
  $ch=GetCharAt($buffer, $ix)
  if ($ch="[")
    print("found start")
    $start=$ix
  elseif ($start>=0 AND $ch="]")
    print("found end")
    $end=$ix
    # break
    $ix=$len+1
  endif
  print("increment ix")
  $ix=$ix+1
endrepeatwhile
print($ix)
print($start)
print($end)
if you remove the ElseIf it works as expected.
$ix=0
$start=-1
$end=-1
  if ($ch="[")
    $start=$ix
  endif
    print("found end")
    $end=$ix
    # break
    $ix=$len+1
  endif
  $ix=$ix+1
endrepeatwhile
print($ix)
print($start)
print($end)
This bug must be recent, i've used before the ElseIf, or did i miss something ?
#17
Let me take a look and see how this can be... stay tuned
#18
An IF or ELSEIF needs an ELSE to finish the clause before the ENDIF.
You can make the ELSE do nothing, but it is still required (at least in EZ-Script. Might be implied in some languages).
Not sure this has always been the case, but it is the difference between the failing and the succeeding cases.
@ptp
Yeah, I edited my post to say I am not sure this has always been the case, but is the difference between the working and failing code. Was to point DJ towards cause of bug, not to say scripts were wrong.
yes i agree with you.
it seems the problem is when the condition is false and no else is found.
OK:
print("***Start")
$a=1
repeatwhile($a<=9)
  if ($a=1)
    Print("1")
  ELSEif ($a=2)
    Print("2")
  ELSEif ($a=3)
    Print("3")
  ELSEif ($a<10)
    Print("less than 10 a="+$a)
  endif
  $a=$a+1
ENDrepeatwhile
print("***End")
if you change the condition:
repeatwhile($a<=10)
it get lost forever:
#22
Fixed for next release (later tonight)...
$start=-1
$end=-1
repeat ($ix, 0, length($buffer) - 1, 1)
  if ($ch = "[")
    $start=$ix
  ELSEif ($ch = "]")
    print("found end")
    $end=$ix
  endif
ENDrepeat
print($start)
print($end)
Outputs:
Quote:
Start found start found end 0 12 Done (00:00:00.0337752)
