Avatar JD icon Avatar JD — 3D Avatar JD simulator with bidirectional servo sync, action sequencing, $SIM_ scripting, EZ-B emulator support and pose/movement visualization Try it →
Embedded Computing
Embedded Computing
Some applications may be large enough to support an embedded PC motherboard. Mini-ITX motherboards are a great solution for this application. The Mini ITX motherboards are usually 17cm by 17cm! And best of all, there are cheap memory card virtual hard drive adapters and 12v power supplies. Most Mini-ITX Motherboards have sound built in, plus USB! This means you can have many peripherals for your robots senses.
Mini ITX Motherboards on eBay
SD Hard Drives
12v Power Supplies
Thanks, this really makes the EZB a bit more portable. :P
Found this today DMP - eBox 3350MX x86 Compact PC its available on the UK Robo Savvy web site for 88 its only 9.5cm X 9.5cm X 2 cm and can support XP
Compact PC
It has built in 3x USB 2.0 ports, Audio In/Out, 1 Ethernet port and 1 VGA port. HDD is provided through an SD card slot.
Probably available through other suppliers worldwide
If anyone was going to do this you should check this site out they have a Miniature monitor that might work with the board and fit in a robot. CLICK ME
