Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
Embedded Control Syntax
Hi there, Sorry if this is a noob question. I'm building my own web interface using the JD and i found these commands here: ez-move text="button title (i.e. Forward)" data-direction="forward" ez-move text="button title (i.e. Right)" data-direction="right" ez-move text="button title (i.e. Reverse)" data-direction="reverse" ez-move text="button title (i.e. Left)" data-direction="left" ez-move text="button title (i.e. Stop)" data-direction="stop" ez-script text="button title">ezscript command</ez-script> ez-camera data-controlname="Camera" data-interval="100"
I am new to this and I was wondering is there some where i can find other commands that I can put into my html Thanks
Hi - We are starting a similar project and would also like to know about which HTML tags we can use to interface our webpage with the EZ-Robot. I did find this link - if it usefull:
There are special html style tags that are used to create buttons for interaction with ARC. These buttons are AJAX, which means they do not reload the page when pressed.
<ez-move text="button title (i.e. Forward)" data-direction="forward" />
<ez-move text="button title (i.e. Right)" data-direction="right" />
<ez-move text="button title (i.e. Reverse)" data-direction="reverse" />
<ez-move text="button title (i.e. Left)" data-direction="left" />
<ez-move text="button title (i.e. Stop)" data-direction="stop" />
<ez-script text="button title">ezscript command</ez-script>
<ez-camera data-controlname="Camera" data-interval="100" />
This might be a place to start... https://synthiam.com/Tutorials/Help.aspx?id=205
