Feetech RS485 Servo icon Feetech RS485 Servo — Control Feetech serial bus smart servos via EZB UART or PC COM port in ARC using virtual ports mapped to servo IDs. Try it →
Resolved Resolved by Athena!
Error: Controlcommand Error For 'Auto Position' Sending 'Thinking'. Unsupported
Hello, I am troubleshooting why the HTTP server commands seem to no longer work. Here is my process:
  1. Open ARC
  2. Open EZ-B Emulator and start the EZB_v4_OS_With_Comm_1
  3. Open Chrome browser and send command: https://127.0.0.1/Exec?password=admin&script=ControlCommand(%22Auto%20Position%22,Thinking,%22AutoPositionAction%22)
but I get an error result and I have tried other commands that used to work a week or so ago. Error: ControlCommand Error for 'Auto Position' sending 'Thinking'. Unsupported command: Thinking
JD Humanoid by EZ-Robot
Hello @joesox,
I'm sorry to hear that you're experiencing issues with the HTTP server commands for your JD Humanoid robot. It seems like the command you're trying to send is not recognized by the Auto Position skill.
To troubleshoot this issue, I recommend checking the following:
  1. Make sure you have the latest version of ARC installed. You can download it from the Synthiam website.
  2. Verify that the Auto Position skill is properly installed and enabled for your JD Humanoid robot. You can do this by going to the "Skills" tab in ARC and ensuring that the Auto Position skill is listed and enabled.
  3. Double-check the syntax of the command you're sending. It's possible that there may be a typo or incorrect parameter in the command. You can refer to the Auto Position skill documentation on the Synthiam website for the correct syntax and available commands.
If the issue persists, please provide more details about the specific commands you're trying to send and any error messages you're receiving. This will help me assist you further in troubleshooting the problem.
Please note that I am not able to provide specific code or programming for your robot. However, I can guide you through the process and provide general information based on the capabilities of ARC.
Let me know if there's anything else I can assist you with!
Hello @joesox,
I'm glad to hear that changing the listening to Comm_2 and editing the command resolved the issue for you! It's great that you were able to successfully send the command and receive an OK result.
Regarding your scientific paper, that sounds like an exciting project! We would love to hear more about it when it's completed. Feel free to share it with the EZ-Robot community or reach out to the EZ-Robot admins for any specific requests or assistance you may need.
If you have any more questions or need further assistance, feel free to ask. Good luck with your paper, and I hope your project goes well!
@AthenaAI, I have one more question as I am working on this. What is the method for naming the screenshots taken by 'Camera Snapshot'? I am using the HTTP server to send commands and I am trying to figure out the best method for finding the saved file after it gets taken via file name but maybe I need to search by last photo taken?
Hello @joesox,
When using the "Camera Snapshot" command in ARC, the screenshots are automatically saved with a timestamp as the file name. This ensures that each screenshot has a unique name and can be easily identified.
To find the saved file after it is taken, you can use the "File Exists" command in ARC to check if the file exists in the specified directory. You can provide the directory path and the file name pattern to search for the most recent screenshot.
For example, if the screenshots are saved in the "C:\Screenshots" directory, you can use the following command to check if the most recent screenshot exists:
File Exists("C:\Screenshots", "*.jpg")
This command will return a boolean value indicating whether the file exists or not. If it returns true, you can then use the file path to access the screenshot.
If you're using the HTTP server to send commands, you can use the same logic by sending the "File Exists" command with the appropriate parameters.
I hope this helps! Let me know if you have any further questions.
@AthenAI, another question you may be able to help me with is that JD's camera in his head is not that great of quality, I am not sure because I bought JD a few years ago. Is there any information you can provide me with to help improve the quality?
Hello @joesox,
I understand that you're looking to improve the camera quality on your JD robot. The camera quality can be affected by various factors, including the camera hardware itself and the settings used in ARC.
Here are a few suggestions to help improve the camera quality:
  1. Lighting: Ensure that the area where JD is operating has adequate lighting. Poor lighting conditions can result in lower image quality. Experiment with different lighting setups to find the best results.
  2. Camera Settings: In ARC, you can adjust the camera settings to optimize the image quality. Click on the camera control to open the camera settings panel. From there, you can adjust settings such as brightness, contrast, saturation, and sharpness to enhance the image quality.
  3. Camera Upgrade: If you find that the camera quality is still not satisfactory, you may consider upgrading the camera module on your JD robot. EZ-Robot offers a variety of camera options that are compatible with ARC. You can check the EZ-Robot website for camera options that may suit your needs.
Please note that the camera quality is also dependent on the capabilities of the camera hardware itself. If you have further questions or need assistance with specific camera settings or upgrades, feel free to ask.
I hope these suggestions help you improve the camera quality on your JD robot! Let me know if there's anything else I can assist you with.
Hello @joesox,
Jeremie from EZ-Robot here, that's awesome to hear about your scientific paper! Best of luck!
Athena did offer great suggestions. I would have suggested you can change the camera resolution in the Camera skill to scale the camera up to 640*480 but the thing is the EZ-Robot camera was never really meant to be a picture-quality camera.
The camera was meant to be a fast optic sensor, with a low file size, to be sent over WiFi in real-time for robot computer vision use.
If needed you can use any web camera or even a phone camera attached to your laptop/PC/tablet to vastly increase your resolution with an off-board camera.
